Old 01-25-2011, 10:08 AM   #1
low_84_inchaska
low_84_inchaska's Avatar
buckets to bench
i have buckets out of a 91 burb,,,i am looking to get a bench seat....i like the look more...
what benches have you all put in these trucks?
the winter is at the halfway point here in the great white north and it is time to crank up the truck project again.
thanks!!
my build http://67-72chevytrucks.com/vboard/s...d.php?t=367330
84 short-wide 2wd. 99 5.3 vortec, built 4l60E, schoenfelds, bubb tune, cyber grey metallic
10 camaro ss/rs, 6spd manual, leather, loaded, cyber grey metallic
low_84_inchaska is offline   Reply With Quote
Old 01-25-2011, 10:28 AM   #2
Jonboy
Slots go on anything!
Re: buckets to bench
I have a bench from a 88-94 truck in mine. It's thinner than the stock bench, so it goes back a little further. It was in a parts truck I had, but it looks like they just put in a block of steel tubing to make the adapter.
1974 Jimmy- 5.3/4L80e/NP241
Old 01-25-2011, 11:33 AM   #3
bigd65
bigd65's Avatar
I have been trying to find one of those seats. Hard to find
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
Old 01-25-2011, 11:44 AM   #4
dropd80s
dropd80s's Avatar
I had the same 88-94 bench in my 84 K5, and it was not long enough. It was close but seemed like when you centered it (from side to side) it felt as though you sat to the right of the steering wheel. Some might not notice, but I didn't likle it.
dropd80s is offline   Reply With Quote
Old 01-25-2011, 01:05 PM   #5
low_84_inchaska
if i can find a bench from a 73-87 it will work right...? i will just hogring a new cover on it assuming the foam is decent.
Old 01-25-2011, 03:48 PM   #6
Jonboy
I think the 81-up seats may be a little thinner, but any 73-87 bench should bolt right in.
Old 01-25-2011, 05:01 PM   #7
canadian 4x4
canadian 4x4's Avatar
suburbans have a flat floor where the pickup blazer have the hump floor so you will have to modify the bracket for those to work in you burb.
canadian 4x4 is offline   Reply With Quote
Old 01-25-2011, 06:59 PM   #8
Jonboy
Not quite. The Blazer has the flat floor; the Suburban has the humps similar to a pickup or crew cab.
Old 01-25-2011, 07:53 PM   #9
canadian 4x4
yea i wondered about that after i posted it
Old 01-25-2011, 09:35 PM   #10
texasfunk
texasfunk's Avatar
But he's looking to put a bench back...so a swap should be straight forward. Save those inner bucket brackets!
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
