Old 03-13-2003, 12:20 AM   #1
r0lf-
Hotwheels?
r0lf-'s Avatar
Rotor Width.
I have a 80' Barebones C10 with a I6 and 3 on the tree. The only real heavy duty option I have is the radiator. I looked on the card in the glovebox that tells all the options and there is nothing about the heavy duty rotors in there.
I measured the rotors and they seem to be a bit more than 1".
The reason for this is because im ordering my drop spindles ASAP, im guessing I still have 1" rotors since its a barebones C10, not some HD C30 or 20.
r0lf- is offline   Reply With Quote
Old 03-13-2003, 02:10 AM   #2
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
The code you are looking for starts with a j. It would be like JB1 or JB3. I know JB5 is heavy duty brakes. What code do you have similar to those.
Without knowing the code, I would guess you have the 11x1" rotors.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 03-13-2003, 12:41 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If you can't find the codes, how many leafs you got in the back?
BTW, there is a 1/4" difference between the 2, so it shouldn't be a "little" over 1".
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-13-2003, 01:33 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Chris:
How is the number of rear leafs (leaves?) related? I have the heavy duty rear springs according to the sticker in the glove compartment (4+overload) but not the heavy duty front brakes.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-13-2003, 01:43 PM   #5
Captkaos
Captkaos's Avatar
Heavy duty springs should have 7 leafs + overload, and they were always paired with HD brakes
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 03-13-2003, 03:25 PM   #6
Slonaker
Slonaker's Avatar
Now I am really confused. I have 4 leafs plus the overload, and I thought my options sticker showed heavy duty rear suspension. I assumed I did have the heavy duty suspension because the two trucks that Woodman from Chevytalk has ('84 and '87 C10s) both have 3+1, and they both sit a little lower than mine.
I also don't have the heavy duty front brakes. I have the little rotors.
How many leafs am I supposed to have?
Slonaker
More confused than usual
Stock '01 Silverado
