Old 01-25-2011, 09:20 PM   #1
scubasteve16
scubasteve16's Avatar
75 Chevy 3/4 ton steering issues
Ok Monday morning I start my truck and let it warm up.....My wife hears what she says sounds like a belt winning... i go out after a few minutes and i smell burnt power steering fluid....Well seems my power steering pump is burned up....So today I buy a reman pump and new lines.....I install them put in new fluid and start truck....Get out of truck get under hood to check fluid and pump is hottttt...and i mean like really hot....It was only a matter of a minute from time I started truck to time i got under hood to check fluid and it got hot that quick....What could be wrong....Fluid didnt drop any at all either so it aint pumping fluid into steering gear box ( I am asumming) ....
"If it throws you back in the seat when it shifts, it was slowing down before it shifted"
Disturbed Customs
1992 Chevy 1/2 ton 4x4 wore out 350
1975 Chevy 3/4 ton 4x4/ 8" suspension lift/ 468 Big Block/ 4 speed/ 4.56 gears/ 17' American Racing simulated beadlocks with Pro Comp 37x12.50 tires
1950 Pontiac Chieftain Straight 8/Hydromatic tranny
scubasteve16 is offline   Reply With Quote
Old 01-26-2011, 01:11 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 75 Chevy 3/4 ton steering issues
when you put fluid in ,move the wheel left to right, but not all the way
this will bleed out the air,the pump might be empty
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-26-2011, 09:10 AM   #3
scubasteve16
I checked the power steering pump for fluid...it is still full...and I tried to move the wheel left to right and its tight...i know it should be a little tight but this seems extremly tight as if the steering is locked...I have changed power steering pumps before and usually when u fire truck up it sucks fluid down but not this time..
Disturbed Customs
Old 01-26-2011, 11:11 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
i didn't think the valve would open till it moved--
hmmm
John
Old 01-26-2011, 07:59 PM   #5
Blue Chevy 1987
Blue Chevy 1987's Avatar
could be a bad pump. just cause its new dont mean ****
Blue Chevy 1987 is offline   Reply With Quote
Old 01-26-2011, 09:57 PM   #6
scubasteve16
Thats what I thought as well.....just cause its a new pump dont mean its good....so I am going to take this one back and get a new one and warranty my gear box out and replace it as well that way I know its all new and cant be any questions.....I know they wont like me when I walk in with a pile of parts and tell them Iw ant to warranty all these out for new ones...LOL....But o well thats why I buy Lifetime Warranty....
Disturbed Customs
Old 01-27-2011, 01:09 AM   #7
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Any time you replace a power steering pump you ALWAYS have to cycle it through to bleed the system. First, you plug the hole on the reservoir where the return line attaches to. There should be a plastic plug that comes with the pump when you buy it. Put the return line into a catch-can/pan/etc. to catch fluid. Fill up the pump, turn on the truck, move the steering wheel left to right, lock to lock. You'll have to do this several times and fill the reservoir accordingly until the steering is smooth, and until the power steering coming out of the return line flows clear into the catch-can/pan. This will get rid of the old, contaminated power steering fluid from the steering gear and will bleed the air out of the system. Then bolt up the return line into the pump reservoir and you're all set.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 01-27-2011, 01:16 AM   #8
scubasteve16
Ya i tried to bleed the system even though it was getting hot...but it was getting even hotter and was starting to boil the fluid and was barely even turning the wheels, even with tires jacked up off the ground...So I am going to just replace everything. So I know its all new...
Disturbed Customs
Old 01-27-2011, 01:16 AM   #9
TheWhiteElephant
God is good!
By the way, doing what I just described will also show you if fluid is being pumped from the reservoir into the steering gear and back into the pump. Hope this helps.
Mando
Old 01-27-2011, 01:17 AM   #10
TheWhiteElephant
God is good!
If this doesn't work, you might have a bad steering gear.
Mando
