Old 03-13-2003, 01:18 AM   #1
CRRoy71
Locking diff???
I was looking at my little sticker in the glove box with all of the options that came with my truck, and noticed that there was an added option Locking differential.
Does this mean front only, or front and rear. How can I tell, and how good is the factory locking diff?
Chris
'92 ext. cab s/b 4.3L "Sparky"
'04 crew cab 2500 4x4 6.0L
CRRoy71 is offline   Reply With Quote
Old 03-13-2003, 02:00 AM   #2
1969 GMC
1969 GMC's Avatar
I am by no means an expert, but probably unless it says "front" on the sticker, its just for the rear axle.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 03-13-2003, 09:24 AM   #3
Blazer1970
Blazer1970's Avatar
If you are talking about the G80 option in your '86, it is a Gov-lock in the rear only.
Blazer1970 is offline   Reply With Quote
Old 03-21-2003, 08:21 AM   #4
CRRoy71
Yep, that's the one.
Thanks for the info.
Chris
Old 04-16-2003, 11:21 PM   #5
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Gov-lock differentials are lockers- not the limited slip style. They do have clutches but lock solid under torque & wheel spin-out. They work good & hold up ok as long as you don't abuse them too hard or give your truck a change to the "bigs," motor, tires, foot, etc.
-Jeff
jeffspower is offline   Reply With Quote
Old 04-16-2003, 11:55 PM   #6
CRRoy71
Right now with this stock 305, I don't think I have to worry about tearing anything up. Hopefully, in the next year or so I am going with more HP, so that might be something to keep an eye on.
Chris
Old 04-17-2003, 12:00 AM   #7
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
A friend has one in a early 90's light (semifloat) 14 bolt & abuses it pretty hard at times. He has a mild 350, 5 spd & 3.73's. He got the rear jumping bad enough one time to snap & axle shaft- but the gov-lock survived!!!
-Jeff
Old 04-17-2003, 06:33 AM   #8
TX_Mudder
Gotta be rear. Other than the military trucks, the general never put a LSD in the front axle AFAIK.
-- Mike
TX_Mudder is offline   Reply With Quote
Old 04-17-2003, 07:37 AM   #9
Blazer1970
Blazer1970's Avatar
-- Mike
Not true. Clutch type posi's were available factory installed in the front axles of '67 - '72 era 4X4s. I have seen glove box stickers posted on this site a few times that prove it.
Old 04-17-2003, 08:32 AM   #10
TX_Mudder
I learn new things every day
On the down side, those Dana 44s would be of the 260x ujoint variety and would be weaker than the more common later axles.
-- Mike
Old 04-17-2003, 10:57 PM   #11
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
some 72's have the larger u-joints, same as the 73-up axles. mine is an early 72 & it does. I am sure the axle is original since my father in law has been around the truck since new (fire dept. truck) & bought it from them in about 1976. I am now the 3rd owner at 85,000 miles.
Just a little info I thought you may like to know!
