01-25-2011, 10:51 PM | #1 |
3"z
i want to z the front of my 69 i will be running 22" rims what other mods will need to be done? How low will it sit any pics of the whole process.. thanks
01-25-2011, 11:57 PM | #2 |
Re: 3"z
Do you know the tire size you want to run on the 22? This will be important for accurate feedback.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
01-26-2011, 12:31 AM | #3 |
Re: 3"z
I will be running 255/30/22
Posted via Mobile Device |
01-26-2011, 01:16 AM | #4 |
Re: 3"z
You could most likely get away with a 2.5" "Z" and a 3" spindle... If you decide to "Z" it... do as little as possible.
01-26-2011, 10:08 AM | #5 |
Re: 3"z
How far down will it sit with a 2.5 and will I have to cut the trans tunnel or any other mods?
01-26-2011, 10:26 AM | #6 |
Re: 3"z
You should lay frame with that. You will need to raise the trans tunnel and possibly notch the rear of the cab slightly.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
01-26-2011, 01:52 PM | #7 |
Re: 3"z
Is going 2.5" compared to 3" going to make me regret not going 3" later on for any reason I want it to be hammered!
01-26-2011, 09:20 PM | #8 |
Re: 3"z
Heres a link to a tech article on doing a 3" Z on a 1986 Chevy frame. It also includes cutting 1.5" off the bottom of the frame under where your feet are to lay pinch weld with no body drop. Plus theres also a trans crossmember as well. The inner side of the frame are plated as well.
http://www.dallashotrodparts.com/1986chevy.html |
01-26-2011, 10:28 PM | #9 |
Re: 3"z
great article thanks alot that cleared up alot of my questions
02-05-2011, 01:20 PM | #10 |
Re: 3"z
I was thinking to z my frame I have a big block and 22 tire size 265 35 22 wil there be hood clearance issues can some one post pics of the work done to cab to tunnel please? Also with a dropmember do you have to cut the cab out? Every time I do a search for z'd no reults
02-05-2011, 02:23 PM | #11 | |
Re: 3"z
http://67-72chevytrucks.com/vboard/s...26&postcount=3
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-05-2011 at 02:23 PM. |
02-06-2011, 12:47 PM | #12 |
Re: 3"z
Try Zing, Z'ed,Zed as key words .Also mess around with ur advanced search settings.It may help cause theres alot of info on here.G/l
02-08-2011, 11:16 PM | #13 |
Re: 3"z
02-09-2011, 02:06 AM | #14 |
Re: 3"z
Usually several of the google hits will be from this forum.
