Old 01-26-2011, 12:36 PM   #1
Dukester
Help needed - 1972 grill assembly pics needed
First I want to say thank you....I am a Ford guy through and through but recently had a good buddy go through a stroke and isn't able to get out and work on his truck. I believe that I have everything to put a grill and headlight assembly on his 1972 C20. Everything is new but I can't figure out for the life of me what type of clips hold the outer aluminum shell to the plastic grill insert.
Both have square holes but the ones in the insert are slotted for adjustability.
Can someone please send me some step by step instructions so I can get my buddies rig together for when he is better.
Thanks!
Dukester is offline   Reply With Quote
Old 01-26-2011, 12:53 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Help needed - 1972 grill assembly pics needed
First, to the forum!
Second, from a stroke survivor....you get a big attaboy from me. I wish I had friends like that, who were able to get me going.
Third, I can't answer your question because I have a '69, with a slightly different grille. So, I recommend www.lmctruck.com to get their picture. It's a line drawing, quite a bit like Mitchell Crash Book illustrations. Should be easy to look at the pic and see how it all works. Here's the link to their page 68. http://www.lmctruck.com/icatalog/cb/full.aspx?Page=68
Member Nr. 2770
Old 01-26-2011, 12:55 PM   #3
matthew20061
69' Chevy Stepside
matthew20061's Avatar
You need to attach the inner plastic grill to the outer with some small clips that you can buy though LMC, I've also used tip ties once just to put it together and later replaced them with the correct plastic clips.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 01-27-2011, 06:33 PM   #4
Dukester
Thank you guys....I have been to the site and it doesn't give a good look as to which clips or even the type of clips that they are.....I am more of a see a pic one time and I can do it. heck I have even tried over 10 different types of the plastic fasteners but once you have them in the aluminum outer shell, and try to use a screw and big butt washer they just spin the clips around.....arrrrggggghhhhhhh!!!!!!
Old 01-27-2011, 09:09 PM   #5
66skylarkpost
66skylarkpost's Avatar
from the repro assmebly manual
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 01-27-2011, 09:14 PM   #6
66skylarkpost
and
Old 01-27-2011, 09:15 PM   #7
66skylarkpost
and then
Old 01-27-2011, 09:21 PM   #8
66skylarkpost
and then
Old 01-27-2011, 10:36 PM   #9
Hubscrub
Cruzin
Hubscrub's Avatar
here is a pic of the clips i ordered mine from classic parts of america for $4.95 + shipping the white part inserts through the plastic inner grill and snaps into the alum. outer grill then insert the screw to spread the clip tight.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 01-28-2011, 03:08 PM   #10
Dukester
Awesome guys...just what I needed!!! So the insert goes through the plastic into the aluminum....that's what I couldn't figure out.
Wonderful!!!!!
Old 01-28-2011, 04:05 PM   #11
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
First off I Hope Your Friend has a Swift and Full Recovery.
Second is How very Cool of you to help him out.
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
