Old 01-26-2011, 05:17 PM   #1
kylecoyote
87 crew cab 4x4
I just picked this truck up and am looking for something cheap for the interior. Does anybody have pictures of a setup from a suburban. I dont think the rears from a sub will come close to swapping the floors look way to different. What about if I used two sets of front buckets with consoles? Any help is welcomed also what about the threshold plates?
Original is the best
kylecoyote is offline   Reply With Quote
Old 01-26-2011, 06:08 PM   #2
Hulk Will Smash
Hulk Will Smash's Avatar
Re: 87 crew cab 4x4
Down here there's TONS of these trucks getting parted out. I picked up a really nice, clean stock back seat for my truck off Craigslist for around $50. I've got 2005 split bench in the front of mine, but I've been thinking about picking up an '89 - '91 Burb for parts and one of the swaps may be to go to the Burb buckets.
Good luck dude. Looks like a lot of potential in that truck.
'87 R30 Crew Cab Dually
It's 11 PM, do you know where your IAC pintle is?
Hulk Will Smash is offline   Reply With Quote
Old 01-26-2011, 07:40 PM   #3
Prerunner1982
Prerunner1982's Avatar
Re: 87 crew cab 4x4
I don't know for sure but by the looks of it, a bench seat from a regular cab appears it would fit your CC both front and rear.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 01-29-2011, 01:17 PM   #4
kylecoyote
Re: 87 crew cab 4x4
Yea i know the regular cab seats swap in but they are alot harder to come by in good shape than burb seats around here.
Old 01-30-2011, 09:20 AM   #5
firenuttz
2lo4me/ntlonuf/ntfstnf
firenuttz's Avatar
Re: 87 crew cab 4x4
heres my setup with some astro van seats
62 GMC swb fleetside~ project: still undecided
84 Chevy 4wd crew cab 8 inch lift and 37" goodyear h1 pulloffs, still rockin the old mans former plate 2LO4ME
65 chevy 1 ton panel~ bagged/bodied duramax plans slowly in progress...
02 Silverado cclb duramax~ sas'd "bro" truck with more rust than imagineable...
firenuttz is offline   Reply With Quote
Old 01-30-2011, 10:49 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 87 crew cab 4x4
the burb rear bolts to the lip and requires the floor supports
and the seats need a lock to hold them upright
the extra front seats looks like a much closer/easier job
may just need to bend seats tracks
and the extra inside floor bracket for the seats
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-30-2011, 01:14 PM   #7
48cj2a
48cj2a's Avatar
Re: 87 crew cab 4x4
I think the only difference in the crew cab seats is the rear seat tilts forward for behind seat access, otherwise the seats are identical. So a 2 door seat should be same as rear seat in crew.
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
Old 01-30-2011, 06:51 PM   #8
firenuttz
firenuttz's Avatar
Re: 87 crew cab 4x4
i put one in the back of my dads crew and all i did was bend the rear mounting tabs up
