01-26-2011, 10:07 PM | #1 |
how good are 3 inch drop springs
i got a pair of 3 inch drop springs and was just wondering how good are they ride wise and would i be able to add like a 1.5 inch drop spindle
01-26-2011, 10:15 PM | #2 |
67-72 parts collector,…
Re: how good are 3 inch drop springs
Most 73-87 drop spindles are 2.5" or 3" drop.
01-26-2011, 10:34 PM | #3 |
id say no against the 3inch spring, do a 3 inch spindl and half a coil off the stock spring
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
01-26-2011, 10:36 PM | #4 |
if i do a 3 inch drop spring and 3 inch spindle that wold be to low
01-26-2011, 11:01 PM | #5 |
6.0 powered square
thats what my truck had, I daily drove mine and the lower control arms and trans mission cross member are all beat up from scrapping the ground and was really ruff ridding on any road that wasn't completely smooth, also the coil springs would move around when you would jack up the front of the truck and was nearly impossible to keep the front end aligned
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
01-26-2011, 11:15 PM | #6 |
Chris
so buy the 2.5 or 3 inch spindles and buy 1 inch or 2 inch coils then if it's too low with 3 inch springs.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
01-26-2011, 11:28 PM | #7 |
if you want a low drop, you're best to get the most drop possible with the spindles first, nothing changes with the front end alignment. if you want go lower still, do the springs, but the alignment gets messed up the lower you go.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
01-26-2011, 11:56 PM | #8 |
Happy to be here
Your not going to like the 3" spring. As mentioned het as much drop as you can from spindles.
Posted via Mobile Device |
01-28-2011, 01:26 AM | #9 |
k thanks alot guys
01-28-2011, 11:31 AM | #10 | |
1978 Scottsdale - celebrating 10 years of teaching me profanity 1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold 1987 k5 blazer - sold... :\ seed money for the 81 1981 k20 4x4 - 5.3 swap in progress Events attended: Spring GOG 2011 Dale JR car show Summer 2012 Gathering at Tommys pickup parts |
01-28-2011, 12:14 PM | #11 | |
The toe will be way off. I always get a front end alignment,... even if they drive perfect after the suspension drop is complete.
01-28-2011, 10:28 PM | #12 |
Chris
good point it would shorten the tie rod ends moving the wheels up and make them toe in, but however I thought the tie rod mount location stayed the same of moved making the tie rods stay in the same place, with spindles?
01-28-2011, 11:31 PM | #13 |
i thought same since tie rods are not being adjusted at all to put spindles dont matter the drop or do they need to be adjusted
01-29-2011, 09:35 AM | #14 | |
To keep the arm from contacting the wheel,... the spindle manufacturer "tweaks" the arm inward, in their design. This allows the front end to "toe out" slightly, (with the original tie rod adjustment). Thus the need for an alignment.
