01-26-2011, 10:57 PM | #1 |
IDEAS On A 49
Recently aquired a 49 3100 from my grandfather..who purchased the truck new in 49. It spent most of its life as a ditch truck. Time to give it a new "life" !! Just looking for ideas that any of you may have. Definately do not want to chop it or bag it. Lowered a bit however would be good. Thinking about a heidts mustang II front end with 2" drop spindels. And for the rear im not sure..maybe just pullen something out of an old vehicle and rebuilding it. with either a 2 or 4link. Only gonna run a nice stock 350. The end result i'd like to acheive is just a nice good looking old truck that can be a summer driver. Everything dosn't have to be new and shiny as it will not be a show truck. Wanna make it look "fairly" new and drive it right back into the ground!! Any ideas or suggestions would be greatly appreciated and i will post as the restoration progesses. Thanks!! New to the forum BTW.
01-26-2011, 11:23 PM | #2 |
Re: IDEAS On A 49
Sorry, but what is a "ditch truck"?
....and that thing looks pretty dang solid from here. How's the cab and such? Last edited by pinecrest; 01-26-2011 at 11:25 PM. |
01-26-2011, 11:25 PM | #3 |
Re: IDEAS On A 49
A ditch truck is a truck that was used on a farm to ride ditch(Irrigate).
And as far as everything..It is solid!! There is one little spot up on the front drivers side of the cab that is rusted through..about the size of an apple. Floor pan, firewall and cab besides the one spot is in good shape. Last edited by Slewis2304; 01-26-2011 at 11:32 PM. |
01-26-2011, 11:39 PM | #4 |
Re: IDEAS On A 49
Hope this works! The truck!!
[IMG][/IMG] Last edited by Slewis2304; 01-26-2011 at 11:41 PM. |
01-27-2011, 12:10 AM | #5 |
Re: IDEAS On A 49
Welcome to the forum you are in the right place for ideas, you can spend days reading on here and coming up with ideas. Guess it depend on what you like,I am building a 49 also, my dad bought it 25-30 yrs ago I got a hold of 10 or so yrs ago, it sat for 30 yrs just moved from one spot to the next a couple times. I thought the body was rough till I joined here. You can check my build out when you get time, Its a work in progress.
I agree with pinecrest it looks like a good solid truck. http://67-72chevytrucks.com/vboard/s...d.php?t=413926
http://67-72chevytrucks.com/vboard/s...d.php?t=413926 http://youtu.be/Qe9xJUhWkWc Last edited by RootBeer 6117; 01-27-2011 at 12:18 AM. |
01-27-2011, 08:22 AM | #6 |
Re: IDEAS On A 49
nice truck......whid
01-27-2011, 11:29 AM | #7 |
Re: IDEAS On A 49
That thing has great patina. Since it's a keeper, I'd do the Heidts thing, put a newer rear axle in it, put your sbc in it backed by an overdrive transmission, throw on some nice wheels/tires and drive it! Very cool truck!
01-27-2011, 11:38 AM | #8 |
Re: IDEAS On A 49
I agree on the patina. If it were me, I'd keep the patina and spend my money on engine, interior and wheels. I'd move the plate down to the bumper. Unless that was my grandfathers idea to put the plate there, then hell...I'd leave it!
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
01-27-2011, 12:19 PM | #9 |
Re: IDEAS On A 49
[QUOTE=RootBeer 6117;4441424]Welcome to the forum you are in the right place for ideas, you can spend days reading on here and coming up with ideas. Guess it depend on what you like,I am building a 49 also, my dad bought it 25-30 yrs ago I got a hold of 10 or so yrs ago, it sat for 30 yrs just moved from one spot to the next a couple times. I thought the body was rough till I joined here. You can check my build out when you get time, Its a work in progress.
I agree with pinecrest it looks like a good solid truck. ............ X 3 Have you looked in Project section, there are MANY GREAT builds going on over there, you will have all of your questions answered with a "few" days of research!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
01-27-2011, 07:15 PM | #10 |
Re: IDEAS On A 49
Since you plan to keep it, follow your heart remember, in the end you need to be happy, if you dont like an idea or are not sure...
sleep on it first its not a race
1953 BBC 3100 427 T-400 12 Bolt Al |
01-28-2011, 08:21 AM | #11 |
Re: IDEAS On A 49
Definitely glad I found this forum..So far all positive feedback and I have started browsing through the project section.. Pretty overwhelming at first with different ideas, but also very cool! I’m pretty dead set on the heidts front end. Still having trouble with what to do as far as the rear go's. but as oldschool53 BBC says it’s not a race! Ill figure something out.
Maybe somebody might know....what would be an easy transition for the rear in swapping out the old that wouldn't require a whole lot of fabrication, and a gear ratio that would handle a 350 with an overdrive tranny fairly well. For the most part truck will be highway driven with a little showing off of course!! I have an idea but some opinions would be appreciated...as I will look into it in the project section as well. Thanks everybody!! |
01-28-2011, 09:39 AM | #12 |
Re: IDEAS On A 49
if you plan to drive it everyday, id dump a cheap genIII drivetrain in it... that will give you more then enough power, fuel economy, and reliability... perfect for a daily driver to "run back into the ground" ...
01-28-2011, 09:53 AM | #13 |
Re: IDEAS On A 49
For this truck i'd keep it simple and traditional. Skip the ifs and go dropped axle and take out a couple leafs. Dropped axle will run you about 3 bills. If you are just looking for a cruiser/workhorse, you keep the ruggedness of the truck parts. I dont have anything against ifs but the older i get the more i like "older" stuff. For the rear find you a suitable width open drive (camaro, etc.)
-that is the plan for my truck... Goodluck! |
01-28-2011, 05:58 PM | #14 |
Re: IDEAS On A 49
We have one in the same story. My great grandpa bought the truck new in 49 he bought a 3100 and used it on the farm. He used it to haul grain. My dad and I wanna restore as if it came from the dealer (almost). We have been checking for rear ends also and it seems like a 63-69 chevy pickup rear end would fit right under the chassis of ours without hardly any fabrication which is what we are going for! Good luck with the build. I'll keep an eye on yours, maybe steal a few ideas lol
Have fun! |
01-28-2011, 06:12 PM | #15 |
Re: IDEAS On A 49
This thing is sweet I love the patina
ONE PIECE AT A TIME http://67-72chevytrucks.com/vboard/s...d.php?t=442320 My Build Thread |
01-28-2011, 09:46 PM | #16 |
Re: IDEAS On A 49
Must II works well with the AD truck. I started with dropped spindles,
however it was too low so I went with stock spindles. There are many good units out there. I got the best price from TCI. There are a few shops that make bolt-in leaf springs (CE/posies)for less than $500. They drop the rear down & are easy to install. I'd start by doing the frame/chassis work 1st & drive it to shows to get ideas on what you like. Your view of what you wnt your truck to look like might very well change. Have fun with your truck.....Don |
01-28-2011, 10:56 PM | #17 |
Re: IDEAS On A 49
If it where mine I'd do all Chasis Engineering bolt in suspension, drop in a small block with a turbo 350 to keep it simple and drive it!
01-29-2011, 01:05 AM | #18 |
Re: IDEAS On A 49
Welcome to the board. That's a pretty decent truck to start with and sure didn't get beat up like the irrigating trucks around this neighborhood do.
The Heidts front end is a good way to go but If you are going to drive it on a daily basis I think the dropped spindles might get it a bit too low. Engine, trans and rear end pretty much has to be what you want an what you feel you can deal with both on installation and start up and on down the road. The newer style engines are great along with the Od transmissions but unless you have the skills needed to work on them you will end up taking the truck to a shop every time it needs work on those systems. As far as rear axles and suspensions look though the build threads on here and the guys have about every variety of rear suspension to pick from. Slick it out an paint it. I'm so tired of guys calling worn out paint and surface rust "patina" and thinking it actually looks good that I could scream. Worn out paint and rust is worn out paint and rust no matter what name you stick on it. Last edited by mr48chev; 01-29-2011 at 01:12 AM. |
01-29-2011, 07:51 AM | #19 | |
Re: IDEAS On A 49
01-29-2011, 08:01 AM | #20 |
Re: IDEAS On A 49
Found this on a Yahoo image search. Pretty much the all around height and look id like to go for. With a few changes and touches of my own of course.
01-29-2011, 09:01 AM | #21 |
Re: IDEAS On A 49
Slew, looks like were pretty close on what we want the end result to be. Not sure if this was the yahoo site you found it on but just in case there are a bunch here.
http://www.flickr.com/groups/advanceddesign
http://67-72chevytrucks.com/vboard/s...d.php?t=413926 http://youtu.be/Qe9xJUhWkWc |
01-29-2011, 09:11 AM | #22 |
Re: IDEAS On A 49
The wheels are 15". The ride ht is 7".......Don
01-30-2011, 12:45 AM | #23 | |
Re: IDEAS On A 49
Bernie |
01-30-2011, 02:18 AM | #24 | |
Re: IDEAS On A 49
weldvair very custom and very cool!! pg thanks for the encouragement I will definitely check out your build thread and more than likely have some questions. Again I’m glad I found this!! I think I’ve built up enough enthusiasm..I’m gonna start with some "research" on top of the "research" I’ve already done..followed up by a little more "research"..then possibly some more "research"! And say goodbye for a little while and really dig into it and start rippen apart! I guarantee I’ll be back with a little more specific questions, and as I make progress will post pics. So not good bye but see you later!!! And be prepared Thanks for everything EVERYBODY!!!! Last edited by Slewis2304; 01-30-2011 at 02:20 AM. |
01-31-2011, 12:14 AM | #25 | |
Re: IDEAS On A 49
