Old 01-27-2011, 12:46 AM   #1
yellowGT
yellowGT's Avatar
How do I install trim?
Im wanting to install the trim that goes around the cab under the back window but how do you do it without the little studs that stick out? Any suggestions?
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 01-27-2011, 12:53 AM   #2
HOTFUN
HOTFUN's Avatar
Re: How do I install trim?
If you don't have access to a spot stud mig you can drill and screw them on with small pan head screws. You might find the right side pan head that will still work as a stud head for the clips. Main thing is to measure from both ends and get a chalk line or better yet a masking tape line across the cab and measure out for the clips. Good luck. Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 01-27-2011, 01:01 AM   #3
yellowGT
yellowGT's Avatar
gonna need it because I didnt get what you just said.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 01-27-2011, 01:02 AM   #4
DREAMER1
DREAMER1's Avatar
A good suggestion is to take plenty of pics...documentation...etc. An tell us wut you did right and wut you did wrong so when I want to do mine I can jus learn from your mistakes. =) thanx
DREAMER1 is offline   Reply With Quote
Old 01-27-2011, 01:11 AM   #5
yellowGT
yellowGT's Avatar
ok dreamer I will try to take pics and doc. everything on how to install cab trim
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 01-27-2011, 01:52 AM   #6
yellowGT
yellowGT's Avatar
oh hell yeah....found some info.
http://www.classictrucks.com/tech/06...all/index.html
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 01-27-2011, 02:08 AM   #7
yellowGT
yellowGT's Avatar
one thing the article didnt mentioned was the amount of white clips. As for the corners I think just one of each side.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 01-27-2011, 03:16 AM   #8
makman1297
makman1297's Avatar
I would just use double sided sticky tape like all of the newer vehicles use. That is what i plan on doing to mine.
makman1297 is offline   Reply With Quote
Old 01-27-2011, 06:48 AM   #9
S10Fan
Old Heap Driver
I added the trim to mine so I can relate to working blind. LOL.
Seriously though, I went to the junkyard and grabbed the parts off a donor and took a bunch of pictures with my phone. You should measure the studs using the back glass opening as a reference. Also measure the distance across and spacing between the studs. Pay close attention to the cab sides and measure 867 times where the side mounting hole is located. The corner trim mounts differently by having a stud go from the trim into the cab side with a nut inside the truck.
The plastic clips, studs and repro trim are all available. I didn't use the studs, I riveted the clips to the cab. I seem to remember the studs being 6-7 bucks each at the time.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 01-27-2011, 02:27 PM   #10
timjt
how do you get the corner pieces off without breaking the clips underneath? Im doing it thisweekend and need help
2001 silverado stolen by family
1983 short n wide custom deluxe SOLD
1985 silverado longbed 305 engine 700r4
OH NO! NOT ANOTHER LEARNING EXPERIENCE!!!
"Just because you can do it, doesn't mean that you should"
timjt is offline   Reply With Quote
Old 01-27-2011, 02:57 PM   #11
S10Fan
Old Heap Driver
There's a nut on the inside, just reach up inside the opening in the pillar. I'm trying to remember the wrench size, 3/8 maybe?
Bryan
Old 01-27-2011, 02:59 PM   #12
allengator
allengator's Avatar
Thats what I was thinking... see no reason it wouldnt work great...
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 01-28-2011, 09:35 AM   #13
timjt
thanks S10fan
Old 01-30-2011, 01:29 PM   #14
BigMike608
BigMike608's Avatar
10mm wrench/socket, I took mine off yesterday to clean them up with some NevrDull and took out a few little dings.
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop
BigMike608 is offline   Reply With Quote
Old 01-30-2011, 11:23 PM   #15
yellowGT
yellowGT's Avatar
was that just one per side or two? LMC shows two per corner.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 01-31-2011, 09:43 AM   #16
BigMike608
BigMike608's Avatar
Mine only had one per side
