Old 03-13-2003, 11:26 AM   #1
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
If you ever develop a tranny leak and cant tell where from...
You might need this. I am postin a pic of it since I want to make sure its the right part firstly and to help others if they ever need it.
Its the TV cable detent Grommet/Oring/Gasket Thingamajigy lol!
only .53 cents at OReilly.
Thanks to the others on the boards that helped me exlpain it to them at the store.
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 03-13-2003, 11:30 AM   #2
BigRed
So, what did they tell you when you asked for the "thingamajiggy"?
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 03-13-2003, 12:22 PM   #3
Low87
been here longer than Liz
Low87's Avatar
They told him they were tired of his consistent flirting.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 03-13-2003, 12:22 PM   #4
1FaastC10
1FaastC10's Avatar
that's a dipstick tube seal.
1FaastC10 is offline   Reply With Quote
Old 03-13-2003, 12:56 PM   #5
chevychic
chevychic's Avatar
On the 700R4 the dipstick tube seal and the detent cable grommet are ALMOST identical...but not quite. If I remember right the dipstick tube seal is just a bit smaller than the detent cable grommet.
ChevyChic
86 Chevy K-10
If I can't be a good example, then I'll just have to be a horrible warning.
"You're braver than you believe, and stronger than you seem, and smarter than you think"
- Christopher Robin
chevychic is offline   Reply With Quote
Old 03-13-2003, 01:01 PM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
It looks very similar to the seal thingy that went between the kickdown cable and the transmission on my TH350. It was about a 1/4 inch in diameter. It looks like the one on the dipstick, but much smaller.
I had a similar problem when I tried to get one for my cable at O'Reilly. Mine was missing, and I had never seen one. The guy at O'Reilly had not either. My book said there was supposed to be something there. I felt like an idiot asking for it. It was like the blind leading the blind!
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-13-2003, 04:57 PM   #7
AirMale
AirMale's Avatar
My turbo-400 leaks through a weep hole in the slip yoke. It's very mysterious. I guess when I lower it 4/6, I'll check the length again and plug up that hole. Any one else have a 400 leaking through the yoke?
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 03-13-2003, 06:00 PM   #8
Slonaker
Slonaker's Avatar
Yes, I had that problem with my TH350. Swervin has the solution on his site:
http://www.73-87.com/garage/yokeleak.htm
Slonaker
Stock '01 Silverado
Old 03-13-2003, 06:23 PM   #9
PHOENIX
I was reading the link to swervin's site and I have a question.
I never thought about this much before, but now Im starting to wonder. I have replaced my clutch a few times and removed my trans even more times. I never marked where the driveshaft was. I just took it off and put it back on. Never seemed to have a vibration or out of balance problem. I thought that when a driveshaft was balanced its balanced out of the truck (vehicle), so it wouldnt matter how you put it back in. Is this right? Is there something Im missing. I will be doing a clutch probly within the next few months, so this has me thinking
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 03-13-2003, 07:47 PM   #10
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
Eddie
It's not so much of a problem just removing the driveshaft and putting it back in. It's when you are replacing the U-Joints is when you don't want to lose the alignment of the yoke to the drive shaft.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
