WHYBYNU when old will do
I just put the bed on my truck after a complete make-over this winter and just noticed that the gas needle goes way past full. Did i miss a wire or have a bad ground?
I havent driven the truck since last fall and the the truck is new to me ( bought it tore it apart and cleaned it up over the winter and ready to put on the road)so I dont remember if it worked or not before I tore the truck apart.. Oh yea its a 84 with 305/350 2wheel drive. ------------------
71 Cheyenne super 2 tone green and white ZZ6 - Th350 4/6 drop 20x8.5 / 20x10 Billet Specialties |
![]() Join Date: Feb 2000
I had the same problem with my '74 K/20. I bought it and had to put a new tank in it. I replaced the ground wire after I got it back on the road and the guage is now working again. Check you power wire too! That could be rubbing on the crossmember or have a bare spot, most likely the ground though. Hope this helps.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
go with mjn, i had that problem twice.once when i had some one put a new flexplate in and they smash the power wire with the crossmember bolts, and twice when i drop the tank, put it back in and didn't have a good ground.
