Old 01-27-2011, 02:55 PM   #1
BlackTopMotors
O-Ring Install & Evap, Drier Opinions - THANKS!
Hey guys,
I just mocked up the evap and drier tubes and am getting ready to do the
o-rings. Seems easy enough, a bit of supplied oi and the correct o-ring...tighten correctly...
Just thought I would put it out there in case anyone sees a possible problem...this is my first time doing AC...hate finding mistakes after the fact.
I don't have a manual to refer to for this and see the drier has the words evap and condensor...do the lines look correct...any tips?
Thanks,
Roger
BlackTopMotors is offline   Reply With Quote
Old 01-27-2011, 05:41 PM   #2
john
member #16
john's Avatar
Re: O-Ring Install & Evap, Drier Opinions - THANKS!
Your evap- cond. lines look backwards to me. You have the cond line into evap port on the dryer. They usually have a directional arrow on them.
john is offline   Reply With Quote
Old 01-27-2011, 06:06 PM   #3
BlackTopMotors
I think you are right! For some reason i thought cond ment to the compressor and evap I was thinking the condensor....I will just rotate the drier change the tubes...Thanks!!!
Any other tips are greatly appreciated.
Roger
Old 01-27-2011, 08:46 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Looks like you are missing your A/C Inlet & Evaporator Tube Grommets that protect the aluminum tubes from the core support. We make them.. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-27-2011, 09:23 PM   #5
BlackTopMotors
Would there be any advantage to using a bit of teflon tape in addition to the o-rings...I want to make sure no leaking...?
Old 01-27-2011, 10:10 PM   #6
hayhauler71
hayhauler71's Avatar
The o rings do the sealing tape is not to be used. Also keep in mind that the dryer has a desiccant inside to absorb moisture so the system should be kept sealed. The drier is normally the last thing installed so moisture is not added to the system. If your still fabing up the system keep the lines capped and sealed as you wrk on it. Good Luck
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 01-29-2011, 01:32 AM   #7
BlackTopMotors
Thanks, I may need to look at getting another drier. Is there anyway to know if it is still ok? When I purchased the truck it came without a compressor...it probably went out and was tossed but everything else looked fine so I have been spending time cleaning, polishing... Thanks for the advice, Roger
Old 01-29-2011, 10:03 AM   #8
mrein3
mrein3's Avatar
That one is only good for mocking up a new one. If you leave them open to the atmosphere they do their job and use themselves up.
I never bought anything from ackits.com but I've read good things about them. I had to look the part up for a 1972 Chevelle but they have them for $17.16. You SHOULD be able to find one at the local auto parts store.
https://www.ackits.com/pc/37-13218/C...+-+Accumulator
When you get your new one leave it sealed until you are ready to evacuate the system and charge it up. Just keep mocking up with what you got.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-29-2011, 03:44 PM   #9
67C10BUB
67C10BUB's Avatar
Good info guys. I am going to be doing my AC system soon, so I am interested as well.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 01-29-2011, 08:52 PM   #10
Zeke
Active Member
When I was doing 134 conversion several years ago I always had problems with orings leaking even when oiled with compressor oil got some of nylog and now I wouldn't put one together without it. One bottle goes a long way.
http://www.ackits.com/c/Nylog/Nylog+...brication.html
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 01-30-2011, 10:26 PM   #11
BlackTopMotors
Thanks for the info, I will just use the old one for setting it up and get another to hook up when ready to do the final steps. Thanks for the link as well. Roger
Old 01-30-2011, 10:32 PM   #12
BlackTopMotors
Thanks for the tip, I hate getting it all hooked up and still finding problems/ a leak. I will definitely look into ordering some Nylog.
I don't know much about Air Cond so this will prepare me for other future projects as well, Roger
