Old 01-27-2011, 03:00 PM   #1
mikemileski
Shift Bracket on TH350
I have a '72 GMC 4x4 with a 350/350. The small bracket (see picture) that is closest to the tranny that's mounted on what I would call the shift shaft has worn so bad on the ends that I have to lift the shift lever way up out of the park position to activate the neutral start switch so it will start. There's no way to adjust things to make it work normally. Any idea if anyone sells new ones? I haven't had any luck locating one, either new or used, and I really want to get a replacement.
Mike Mileski
Tucson, AZ
mikemileski is offline   Reply With Quote
