Old 01-27-2011, 03:16 PM   #1
MrDude_1
2nd row Yukon Seat??
What do you guys think of this seat?
notice its the SECOND row, not the far 3rd row backseat
Im thinking it will work well, but i havent seen it in person or in the truck. Has anyone tried a Yukon/suburban middle row seat? EDIT: I should mention this is for a 51 chevy.. an AD truck not a TF.
The guy wants $125 for it... would you consider that a good deal?
MrDude_1 is offline   Reply With Quote
Old 01-27-2011, 03:21 PM   #2
kaycee
kaycee's Avatar
Re: 2nd row Yukon Seat??
Seems like a fair price for a no tear or ripped seat,don't forget to get the center seatbelt.And don't forget that the seat will not have forword and back adjustment,I think a guy could fab 1 up using sliders from a nothe vehicle
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 01-27-2011, 03:45 PM   #3
MrDude_1
good call on the sliders. i didnt think of that.
thinking about it now....I dont think that would be a big issue for me.. the seat is going as far back as it can, and then staying there. lol.
Old 01-27-2011, 04:28 PM   #4
OrrieG
OrrieG's Avatar
If they are not worn, do not have tears and are not really filthy its a good price. Around here they usually start at $250. I built my third row bracket so it has tilt adjustment, steering wheel telescopes, pedals are fine.
OrrieG is offline   Reply With Quote
Old 01-27-2011, 04:59 PM   #5
Houston54
What kind of truck are you considering this for?
The width is workable for a Task Force truck but too wide for an AD.
One thing to consider on any seat is how well centered the seating position is behind the steering wheel. If it is off center significantly it makes it look like an after-thought.
I am considering using this seat time on my 58 project as I do not need it to move up or back, and it provides very good access under it and behind.
A better option would be the front seats with the integrated seat belts and the jump seat that goes between them.
Houston54 is offline   Reply With Quote
Old 01-27-2011, 05:24 PM   #6
gnstalodz
I have these in my 72. I love it. It's very nice, has a middle arm rest and cup holders.
gnstalodz is offline   Reply With Quote
Old 01-27-2011, 05:32 PM   #7
MrDude_1
mines a 51 AD...
I had the guy measure it, and the total width of this seat is 56"...
from reading on here, i understand that it is the maximum width i can fit without issue, but it will fit. is that correct?
Old 01-27-2011, 08:26 PM   #8
tmoble
yeah, but the drivers seat might/won't be centered behind the steering wheel. if you're comfortable with that you're OK.
tmoble is offline   Reply With Quote
Old 01-28-2011, 09:34 AM   #9
MrDude_1
my truck isnt assembled at the moment, so i cant look at this for myself but...
why cant I just mount the steering column over further?
I mean, the steering column isnt currently centered between the two gauges.... I kind of like the idea of moving it all over some to center the wheel anyway.
has anyone here done this?
Old 01-28-2011, 10:06 AM   #10
62ChevyII
Yep you can do that. I moved the steering wheel over to be centered on the gauges when I put the S10 column in the 48 I built.
62ChevyII is offline   Reply With Quote
Old 01-28-2011, 11:28 AM   #11
MrDude_1
did that put you "too close" to the door when you're sitting in the truck?
i already know im going to prop my arm up on the window 90% of the time, but when the window is up, am I going to be wedged on the door?
Old 01-28-2011, 11:47 AM   #12
62ChevyII
No, I thought it was fine. I'm not huge, about 6' and 200lbs and it was comfortable to me. I actually sold the truck before I got to drive it but sitting in it seemed like it fit pretty natural. There is the issue of the notch in the dash for the column. A guy could fill that in if it bother's him. I think Chevy offset it becasue they used usch a big steering wheel from the factory.
Here's a shot of the wheel and dash:
Old 01-28-2011, 12:38 PM   #13
2ndGenRR
2ndGenRR's Avatar
I moved my column over for 2 reasons...1. to center it between the gauges, and 2. so that i could move lower end of the column over a couple of inches for header to steering shaft clearance. I also made a piece to block out the factory column indent in the dash. It works nice and looks right and in no way puts the steering wheel too close to the door. In fact, I find the elbow on the window frame to steering wheel to floor shifter arrangement right comfortable. I don't have a pic at the moment, but I can take one this weekend and post it up.
Oh and I'm using a 2nd row Dodge Durango seat...good width, could be a little wider, but it mounts easily and the seats fold down and flip forward giving easy access to the "storage" area under the seat. It also has a center armrest with built in cupholders and the headrests do not stick up into the window area, which was a must for me.
The Stable:
1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me.
1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck.
1951 Chevy 1/2 ton, 3-window...building to sell.
Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado.
I grew up in Flint, Michigan so I can't help but to bleed Chevy!
2ndGenRR is offline   Reply With Quote
Old 01-28-2011, 12:50 PM   #14
MrDude_1
http://i38.photobucket.com/albums/e1...7-30-09009.jpg
thanks for the pic.
i think you're right about the wheel size.. never occurred to me, but by using a smaller wheel, and moving the wheel over, my hand/arm would actually be in the same place anyway..
I am already planning on filling in some parts of the dash, i think if i cut the left side of the 'notch' in your pic, and cut out a little sliver, i could make a wider, centered notch, and then mount the column to go through it.. my column would then be about 2" higher then yours.. and since im making the firewall hole anyway, i can then move it to correct the angle. steering wheel angle can still be adjusted by the column tilt function.. plus it can be made to clear the headers easier.. win-win-win.. but sounds like alot more work.. lol.
Old 01-28-2011, 10:34 PM   #15
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
I speak from experience. I bought the same seat, paid 200.00 for it and bolted it in without noticing how it really fit. Oh yeah it set in there ok but you will not be able to install your windlace on each door opening. I sold it and bought a seat from Wise Guys. The bottom link is a picture of the seat and the guy that covered it.
http://s729.photobucket.com/albums/w...t=PB300001.jpg
http://s729.photobucket.com/albums/w...rrent=SEAT.jpg
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 01-28-2011, 10:43 PM   #16
tmoble
man, those things are pricey.
Old 01-28-2011, 11:59 PM   #17
BIG CHEVY 3600
Yeah, pretty rich for my blood as well. However it has everything you would want including that center fold down arm rest, two outlets, seat heaters, adjustments and reclines. Total with foam was around 1K but well worth it. Another $400 for the upholstery.
Abraham Lincoln
Old 01-29-2011, 09:23 PM   #18
lazypineapple
lazypineapple's Avatar
astro van 2nd row seat
The original seat is 52" width.
56" will fit , but its gonna move the drivers seat Butt pad closer to the door.
I found a Astro van 2nd row seat its 52" wide.
I bought a cloth one for $40
this leather one they wanted $150
lazypineapple is offline   Reply With Quote
