03 z71 tranny problems
i was looking at a 03 z71 today.
specs: leather interior,60k miles, 4 inch lift. very niice on the outside. taking care of. problems: transmission will not go in d or first, but will go once you put it in second and it drives fine after that, shifts good as well. just no go on first and drive. it was driven on a trail by a kid and it was broke when he went into a rut and pressed the gas while the back tire was in the air and it gripped when it hit the ground. what could be the problem? simple fix? or does it need a new transmission? please help me, im a college kid needing a newer truck |
![]() Join Date: Sep 2005
Re: 03 z71 tranny problems
Sounds like a trans problem
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
i know that but like a easy fix on the tranny. or do i need to rebuild? get one from a junkyard?
If it only moves in the manual 2nd gear position your Forward Sprag and Low/Reverse roller clutch are broke. If it moves in Low & second gear positions the Forward sparg is broken. Either way the transmission will need to come out & be torn apart.
you seem to know. how much you think that would run me?
69' Chevy Stepside
![]() Join Date: Mar 2008
I know around here you can find a used 4L60e for around $600 in working condition from the junkyard, so maybe look into that if it needs a new transmission.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
if iwas to get the forward sprag and reverse roller replaced. how much would that cost?
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
how well can you wrench is the big question, if your pretty good or very good, you could swap out the trans for a good used one, if your not and would need to take it to a pro, a rebuild would probably set you back a couple grand or more. If it were me,
1. pass on the truck. 2. have the owner now repair/replace the trans and then reconsider #1.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 01-28-2011 at 07:09 PM. |
i wouldn't just replace just the forward sprag and reverse roller. most shops wont anyway they will want to rebuild the whole thing
