Old 01-27-2011, 03:58 PM   #1
Ynotnow817
Ynotnow817's Avatar
swap to a th350?
Tonight I am going to remove the manual trans crossmember off of my 65 c10. Do you recommend grinding of the clutch bracket that is bolted to frame also?
Ynotnow817 is offline   Reply With Quote
Old 01-27-2011, 04:20 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: swap to a th350?
Only if its in the way.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-27-2011, 04:21 PM   #3
SFTorange
SFTorange's Avatar
I left my clutch bracket in place. I don't think it is in the way of anything. Good luck with the crossmember. It was a huge pain. Lots of patience, a long punch, and a BFH will help a lot. If you're doing it with your cab on, it might be a good idea to use a reciprocating saw to cut the bracket off as close to the frame as you can get in order to provide more clearance for the grinder.
SFTorange is offline   Reply With Quote
Old 01-27-2011, 04:28 PM   #4
Ynotnow817
Ynotnow817's Avatar
thanks guys.
