Old 01-27-2011, 05:04 PM   #1
biohazardbill
Removing front coils, crossmember not in truck
Anyone have some good ideas for removing coils from the front crossmember while it is not in the truck?
Got a new crossmember and want to clean it up, paint etc.
biohazardbill is offline   Reply With Quote
Old 01-27-2011, 05:15 PM   #2
Ynotnow817
Ynotnow817's Avatar
Re: Removing front coils, crossmember not in truck
I borrowed a spring compressor from Oreilly's. Had to torque it down pretty hard then I removed the U blts from lower arms and pulled out spring. Good luck.
Ynotnow817 is offline   Reply With Quote
Old 01-28-2011, 08:57 AM   #3
Scot_Douglas
Scot_Douglas's Avatar
I wish you were still local - I have one sitting here you could have.
I'd go with a spring compressor - I just wrote all the crap in the quote below, before remembering the top 1/2 of each front coil were broken - so I started off with a shorter spring and had less stored energy in my setup. It may not work for you, and I don't want to tell you something that hurts you - well , at least something not that bad.
I did what you are asking to do - in a sorta destructive way: I put a large c-clamp through the spring and the other end on the bottom of the lower arm and tightened it - this was just to make sure the spring didn't wind up anywhere near my head when I the next thing:
From there, I unbolted the upper a-arms and pulled them off the studs. Then I used a cutoff wheel on the clamps that hold the lower arm to the crossmember. They'll "pop" open about a 1/4" when you cut through one side - that pretty much released the spring tension and I could finish cutting them off.
After that, I could pull the whole control arm/spindle away and just had the crossmember.
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
