Old 01-27-2011, 07:46 PM   #1
muckyp
muckyp's Avatar
What is this port for?
I just got my new brake proportioning valve put on and realized there is an extra port on top of it. What is this for? Do I need to find a plug for it? Surely the little plastic thing that is in it won't work.
70 SWB 454/TH400
muckyp is offline   Reply With Quote
Old 01-27-2011, 08:12 PM   #2
69sixpackbee
Re: What is this port for?
Bleeder screw.
69sixpackbee is offline   Reply With Quote
Old 01-27-2011, 08:17 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I believe that is an extra port. Just get a nice brass plug at the hardware store and put it in.
LockDoc
Leon
Old 01-27-2011, 08:24 PM   #4
BlackTopMotors
Maybe this will help? Probably used for a different set up you should check online and or with the manufacturer/seller...
BlackTopMotors is offline   Reply With Quote
Old 01-27-2011, 08:27 PM   #5
ERASER5
ERASER5's Avatar
That port is for splitting the right and left front brake lines. Basically it replaces the "T" joint at the frame. Use it or the original "T", either way is fine.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-27-2011, 08:37 PM   #6
muckyp
muckyp's Avatar
Thanks guys. I will try to find the proper plug now.
70 SWB 454/TH400
Old 01-27-2011, 08:56 PM   #7
69sixpackbee
Hmmm makes me wonder about mine..I have a bleeder
Old 01-27-2011, 09:45 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Mine does also, and I *think* it's original. The truck was just five years old when I bought it.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 01-28-2011, 12:52 AM   #9
muckyp
muckyp's Avatar
Picked up a plug at Oreilley's for a buck sixty. Problem solved. One step closer to it moving! Thanks again. More questions coming soon.
70 SWB 454/TH400
Old 01-28-2011, 02:42 AM   #10
Jeffs70
Jeffs70's Avatar
mine also has a bleeder
Jeffs70 is offline   Reply With Quote
