01-27-2011, 10:36 PM | #1 |
67 Chevy Stepside
454 price check plz
i am in NC what a good runing 454 going. I found a 82 long bed 4x4 with a good runing 86 dually 454 in it. the tranny is got no reverse and the bed sides is a little rough. the passger door is nice good ralleys wheels and decent tires driver door got a little bit of rust he asking 900. is that bad all i want is the motor and wheels rest ill junk
1967 Chevy stepside 1976 BIG DOOLEY 454 turbo 400 4:11 |
01-27-2011, 11:01 PM | #2 |
Re: 454 price check plz
I believe the core value of a 454 on a rebuilt engine purchase is $400-$450, assuming that it is rebuildable. Sounds like you might be able so salvage/sell some parts off that truck and maybe get $500 for those other parts, so that would justify the $900 asking price, IMHO, but why not try $800 cash in hand and see what he says? A 454 is a great engine when it is running well, but it is pricey to rebuild, compared to a 350.
01-28-2011, 08:33 AM | #3 |
It depends on what you want the 454 for. If you're just going to rebuild it with the stock peanut port heads and a little bit bigger cam, it'll be a hoss for sure. If you're going to add large ovals, etc., it'll get a bit more expensive. I can generally buy complete 454's here with large ovals for around $250 - $300, peanut port head motors are $200 or so.
tucsonjwt, a stock rebuild on both is about the same, less than $100 difference. Machine work is all exactly the same, bearings and rings are the same, pistons may cost a bit more but not much. Matter of fact, big block oval port heads can support 700+hp when ported, you're waaay into aftermarket stuff with small blocks built to the same level, GM never made any really good flowing smallblock heads. |
01-28-2011, 11:22 AM | #4 |
I paid 1k for my 79 1ton with a great running 454 with about 60k on it since overhaul. I paid $500 for my low miles 454 out of a motor home. I got about $2500 in my fresh rebuilt 454 and still dont have a cam, timing chain or bolt kit. 900 for a running 454 truck is ok. Just plan on rebuilding it or atleast freshing it up. I feel 300-600 is the going price for a complete 454 depending on the shape its in.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
01-28-2011, 05:31 PM | #5 | |
The Fleet........ 68' Camaro - 1st car (restored & still have it) 09' VW Tiguan (Wife's Daily Driver) 14' VW Passat SE TSI (my personal) 14' Ford Edge Sport (Daily Work Vehicle) 73' SWB Stepside - 77K org. miles 74' LWB 454/TH400 - drive train transplant for my (Sold) 98' SWB C1500 W/T - shop truck (Sold) 90' GMC Sierra SLE short step - aka " Jezabelle " (Sold) |
01-28-2011, 05:34 PM | #6 |
sounds fair to me as long as the 454 runs good...
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
01-28-2011, 07:10 PM | #7 |
67 Chevy Stepside
motor run great dont need a rebulid i cant find small blocks for less then 500 here
01-28-2011, 07:18 PM | #8 |
Old Heap Driver
I paid a grand for my 454 along with an overdrive transmission, both from a 95 motor home. The 454 was a 41k mile TBI motor, I sold the transmission for $500.00. The transmission was an electronically controlled heavy-duty model with the brake drum style parking brake.
The motor is a peanut port version, but I wasn't looking for high performance. I sold the TBI and manifold then replaced both with a Weiand and a Holley 670 Street Avenger. The older I get, the more I like stock. LOL.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
01-28-2011, 08:49 PM | #9 |
you may need to come one state down....im getting whole vehicles with sbcs for less then 500
01-28-2011, 08:54 PM | #10 |
Old Heap Driver
You might want to check Craig's List down my way. You know things are way more expensive just outside the beltway.
01-30-2011, 08:10 PM | #11 |
This is definitely true. I am on the Hampton roads c'list from time to time. My cousin in law lives in Hampton (he is building a 57' Ford panel) and one of my good buds lives in va. Beach. Can't find a running 454 up here for less than $800..............
01-30-2011, 10:11 PM | #12 |
Just picked up two twin 1973 marine motors last week. One turns over fine and the other is stuck for now. Have take the head and pan of the stuck motor and found it's been bored .030 over and has TRW 9.7 compression forged pistons and some rust in a couple of cylinders. Bottom end is quite clean though. Two bolt main, cast cranks, large open oval ports.
Got both for $300 and that included 3 cast intakes, 3 carbs, lots of marine manifold parts and the bonus was a Factory GM aluminum dual plane rectangular port manifold in good shape.Should be worth a couple bucks to sell.
'70 Malibu with 383 stroker/T350 '56 SWB Mercury pickup..under construction '67 Firebird Convertible...all done stock '70 LWB 350 on propane...beater '69 LWB 350/T400 body restored |
