Old 01-27-2011, 11:29 PM   #1
SS317
SS317's Avatar
Gauge question
I have the original instrument cluster in my truck. I have an aftermarket Chevy 350 in my truck. Right now I don't see the needle move at all for temperature. It's about 1/3 of the way over and stays there. If I get the temp probe that is suppose to be on the original engine, wouldn't it work the same on the 350? I don't think whoever installed the engine ever hooked it up. The only gauge that works is the engine oil pressure, it seems to be reading accurate. I can get one at the local NAPA for 6 or 7 bucks.
My fuel gauge is on E all the time. I'm going to check all my grounds and pull the sender from the tank tomorrow to see what I have, and ring the wires to make sure they are correct.
SS317 is offline   Reply With Quote
Old 01-28-2011, 01:36 AM   #2
Captainfab
60-66 Nut
Re: Gauge question
That depends on the year of the engine. More specifically the heads which is where the sending unit will go. The original sending unit for your truck will have 1/2" NPT threads. Starting somewhere in the mid 80's GM changed the size of the threaded holes in the heads to 3/8" NPT. If your heads do have the smaller holes, there are a couple options. Check it out and let us know.
