![]() Join Date: Nov 2010
Need Information on buying whells with 6 hole!
T hings I've read out here is that they may not fit because shafts they cutt holes for! I neeed a little help have some in the area that are from like tahoes , so need the infromaition on if could buy these and work on my truck? PLEASE, PLEASE, CORRECT OR EDUCATE ME
Re: Need Information on buying whells with 6 hole!
I think what your asking is will Tahoe wheels fit on your truck?? Measure the Centerbore of the wheels that you want. On my truck 1970 6 lug the centerbore is 4.25197" or 108 MM. I think you will find new wheels have a much smaller centerbore, that you would need to have milled out. There is a ton of stuff on here about it.
WOW! Thougt that Chevy, hadn't changed things to much. Thanks with that info I will either by tubes or just by new tires. Glad found out before bought them, if had a CNC or able to get to one would be diffrent.
Its Topless Season!!!!
Not only that but the new wheel's backspace if way off. They will not look right unless you use spacers to bring them out.
