CAB Swap
Looking to swap my 58 cab for a 56 will the hood hinge points match up ?Was told they were a little different but could work.Some others saythey are a direct swap did a search and found nothing.Thanks for the info
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
Yellow truck club
Re: CAB Swap
Are you staying with the 58 front end and just changing the cab?
There was a thread about using a 55-57 front with a 58-59 cab and the mounting points are different for the hood hinges. The guy on here will chime in with the measurments I'm sure.
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
Re: CAB Swap
YESSir staying with the 58 front clip want to use the cab and doors from 56
