Old 01-28-2011, 03:16 PM   #1
1low
spring rate?
What spring rate are u guys runing on rear coilovers for street use. im runin 72 swb 4 link
1low is offline   Reply With Quote
Old 01-30-2011, 06:36 PM   #2
robnolimit
robnolimit's Avatar
Re: spring rate?
It depends on shock lenght. As a golden rule, I try to get 5" of static spring compression at Ride hieght. The rear of a c-10 is about 1500 lbs. half per side = 700. If you could get 5" of static compression, that would be a 120 lb spring. Most set-ups won't allow for that, 3" to 3 1/2" is more realistic, 700 div. by 3 = 233lbs/in spring, or 700 div. by 3 1/2 = 200lbs/in spring.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 01-30-2011, 09:15 PM   #3
1low
Re: spring rate?
thanks 4 the info i been reading up on your make it handle thread been lots of help
Old 02-02-2011, 08:59 AM   #4
Wild83C10
Wild83C10's Avatar
Re: spring rate?
Also consider the angle of the coilovers, that will play a factor in the spring rate as well.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
