01-28-2011, 03:53 PM | #1 |
thinair
81 up dash pad
Light grey dash pad.........one small crack on the far RH side that I did not see until I had this removed.......Small crack on the LH side, will not be see when the vents are in......Small crack on the RH side vent opening, between vent and windshield......These are small enough that they can be glued,or whatever you want to use, to stop them from getting any bigger.........The RH insert isn't anything to write home about,but is there and complete......$175.00 plus the ride
