Old 01-28-2011, 04:31 PM   #1
Surfdaddy
Surfdaddy's Avatar
61 GMC Project
I was given a 61 GMC 3/4 ton truck. (This is the 3rd car/truck that has been given me in the last 2 years). Anyway it's been sitting since the early 90's and I finally got it running. Only 77k orig. miles on it. I think the truck is pretty well equipped since it has V6, 4spd auto, coil springs in rear, big back window, a/c and custom interior. Still have the orig radio, and spot light. I got it running ok but need to still do the brakes. I wnat to put power brakes on it so with the single reservoir master cylinder can I just add the power booster or do I need to re route th brake lines and make it a duel circut. How effective will that be in stopping the truck compaired to the stock set up. I know going to disks would be better but with the torsion bar set up I don't know how practical it would be.
the last GMC I had was a 63 1/2 ton with leaf springs and 4spd, that was in the early 80's. Great truck
Surfdaddy is offline   Reply With Quote
Old 01-28-2011, 04:44 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 61 GMC Project
Welcome to the forum. A power booster won’t improve your braking at all, it will just reduce the pedal pressure required to stop. If you want to go discs on the front there are a variety of kits available that allow these to be adapted to the original torsion bar suspension.
http://www.earlyclassic.com/catalog....onversion+Kits
http://www.classicperform.com/6092chevtrk.htm
If you want to educate yourself on everything known about disc brake swaps on these trucks, the following thread is the best resource available anywhere:
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
Old 01-28-2011, 04:57 PM   #3
Surfdaddy
Surfdaddy's Avatar
Re: 61 GMC Project
Your right, I should have phrased it better, I know the only thing that will happen is the peddel pressure wil be less. I don't know it I want to go to disks yet. I had a power booster on my 63 that was dealer installed and it didn't seem to make any difference on the peddel pressure. It was probably worn out or the diaphram was leaking. It just made a swooshing sound when the brakes were applied. Most of the disk kits that I can find are listed for 1/2 ton trucks. I don't want to run two types of wheels. Or rework the rear end. (dana 60) Actually I would like to restore the truck to as stock as possible with adding a overdrive trans, power steering and brakes. Looking for a better alternitive to 1000 buck for the adapter from Hydramatic. Though, I got offers to sell me teh OEM adapters for 400 buck which while I am thankful for the offers I'm not quite ready to jump in until I can find out more.
Old 01-28-2011, 06:52 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 61 GMC Project
I didn't catch the 3/4 ton on the first pass. Post pictures when you can, everybody here loves photos.
Old 01-28-2011, 07:19 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 61 GMC Project
IDK, but couldnt you put a 3/4 ton spindle/a-arms from a 73-87 gm truck on it? is the bolt pattern the same? Im asking not telling.
OK, stupid me, I just saw the 1961. never mind guys.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-28-2011, 07:23 PM   #6
Surfdaddy
Surfdaddy's Avatar
Re: 61 GMC Project
Here are some pictures of my 61. I just removed the camper which was pretty sketchey with the orig cable lift. (finding the CG in 25-30mph wind) As far as I can tel from the orig owners son the camper was only removed once to repaint the truck. The wook in the bed still has the black paint / stain. http://flic.kr/p/9dUaFo
Old 01-28-2011, 07:28 PM   #7
Surfdaddy
Surfdaddy's Avatar
Re: 61 GMC Project
Lets see if this works.
Old 01-31-2011, 05:43 PM   #8
Surfdaddy
Surfdaddy's Avatar
Re: 61 GMC Project
Here are some more pictures
Old 01-31-2011, 10:06 PM   #9
jbgroby
jbgroby's Avatar
Re: 61 GMC Project
Your project looks sweet, the same paint pattern that I have (2 tone) does the spotlight work or a fake? You have the custom package with the RARE chrome trim around the windsheild ruber DO NOT PART WITH THAT! What you plan on doing with the camper top?
jbgroby is offline   Reply With Quote
Old 01-31-2011, 10:51 PM   #10
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 61 GMC Project
That is a cherry looking truck, and you sure can’t beat the price. Other than a couple of rust spots it looks completely untouched. The only GMC’s I’ve seen with the stainless windshield trim have the poorly fitted deluxe trim around the side windows, but they may have been the newer 64-66 cab design. I also don't recall ever seeing side trim like that before. There are so few GMC’s of this vintage with the deluxe trim I’m completely unfamiliar with what an upgrade trim package offered.
Regarding the windshield trim, as Jake noted it’s very hard to find and valuable. Also it cannot be removed from the gasket until the glass/gasket is off the truck, so if a windshield replacement is in the future, resist any temptation to pry the trim out of gasket before it is off the truck.
Should the spotlight need any repairs the following link may prove helpful:
http://67-72chevytrucks.com/vboard/s...d.php?t=403869
Old 01-31-2011, 11:49 PM   #11
Corts60
Just here to tinker
Corts60's Avatar
Re: 61 GMC Project
What's crazy is that truck is so beautiful and untouched but it seems that along the way someone put a 62-66 bezel in the dash...
That truck is awesome and, like Jake said, KEEP that trim around the windshield and on the back side of the cab.
Congrats!
Old 02-01-2011, 12:54 AM   #12
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 61 GMC Project
Wow I hadn't seen the trim on the back of the cab. That has to be the rarest piece of trim in existence on any 60-66 Chevy or GMC. It appears to be different than the Chevy version, which is also exceedingly rare.
Old 02-01-2011, 12:14 PM   #13
Surfdaddy
Surfdaddy's Avatar
Re: 61 GMC Project
The friend who gave me the truck also gave me all the paperwork he had. I have the workorder from the dealer as well as all the sales brchures and quotes from the other truck makers. This guy did all sorts of comparisons, gear ratios, options, prices. He ordered the truck and the camper the same week. When the truck came in he took it to the camper dealer and had it put on. It didn't come off until he repainted it in the 80's. He replaced the instrument bezel at 10k miles (he has a tag with the milage on the orig bezel). The truck still has teh orig fabric on the seat. I have a second set of mirrors and heater core, radio delete plate and orig radio. I'm being very careful not to damage anything when I remove it so it can go back on after the body work is done.
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Old 02-01-2011, 12:19 PM   #14
Surfdaddy
Surfdaddy's Avatar
Re: 61 GMC Project
I had to replace all the window rubber on the squareback I just finished. I cut the trim out while the window was still in the car and polished it and reinstalled it on new rubber. That was a big pain but I'll do the same with this. Though I think the trim is much stronger than the VW trim.
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 02-01-2011, 01:27 PM   #15
jocko
jocko's Avatar
Re: 61 GMC Project
Ok, I'm dying to see this truck, but I'm only getting big red "you wish" x'es in the place of the posted pics above.... HELP!
Old 02-01-2011, 01:32 PM   #16
Surfdaddy
Surfdaddy's Avatar
Re: 61 GMC Project
I have been using Flicker and it used to work on the fiberglassics fourm I was on while i was restoring a boat. Something has changed since then and the URL looks different. I've got a question in to the this site administrator but haven't got a reply yet. I may have to go to some other photo share site. Any ideas? what site works ?
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 02-01-2011, 08:24 PM   #17
Surfdaddy
Surfdaddy's Avatar
Re: 61 GMC Project
Found a way to post pictures. Seems like I was missing something.
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 02-01-2011, 09:15 PM   #18
Dinos63
chevy only
Dinos63's Avatar
Re: 61 GMC Project
what a nice truck!!!!i would think its pretty rare
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 02-01-2011, 10:10 PM   #19
jbgroby
jbgroby's Avatar
Re: 61 GMC Project
One other thing I noticed, I think you have the correct OEM mid-year 1960 hubcaps.
By the way you need to also join Jolly's National 60-66 GMC V-6 club.
http://www.6066gmcguy.org/
This site has EVERYTHING you ever want to know or learn about the 60-66 GMc V-6. Other than the faded blue, your truck and mine are 99% the same (no A/C on Mine)
Old 02-01-2011, 11:06 PM   #20
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: 61 GMC Project
Very nice...and rare ..truck you've got there
Ditto on the later dash bezel
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 02-02-2011, 11:30 AM   #21
Surfdaddy
Surfdaddy's Avatar
Re: 61 GMC Project
The truck is completely stock. I even found spare OEM GMC points adn some parts in teh box of spares along with a new DELCO dist cap. The camper has some water damage (actually a lot) and you may see in teh picture that the dirvers side of the camper started to buckle when I was liftign off the camper. When I got the truck I intended to restore both the truck and camper. I thought it woud be really fun since I like wood working and working on cars. Combine the best of both worlds. But after looking at the camper all teh windows leaked and the vents. I may have to scrap the camper, which is too bad since it has a early Dometic fridge, 3 burner stove and porslin sink.
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 02-02-2011, 07:31 PM   #22
RockTonka
RockTonka's Avatar
Re: 61 GMC Project
It would be really cool if you could restore the camper also. The original owner put alot into having that set-up just right...almost looks like the camper was built around the truck. Neat truck/camper!!
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 02-02-2011, 07:51 PM   #23
Surfdaddy
Surfdaddy's Avatar
Re: 61 GMC Project
The camper was built to his specs. The width of the truck couldn't be any wider since it had to fit through the gate in his back yard. He had it fitted with a 10 gal propane tank. In intereior is all ASH but like I said it would take a lot to restore it. I'm lookin into if I can fit in my garage on the dollie that came with it. I have all the sales stuff that goes with the camper and all the other ones he looked at form all the manufactures in So Cal during that time. I've filled a 3" binder with all the papaerwork. Really cool going through all this stuff.
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 02-09-2011, 01:21 PM   #24
Surfdaddy
Surfdaddy's Avatar
Re: 61 GMC Project
One step closer to bringing it home. Got the brakes bled and stripped out the camper, removed the stove / oven Fridge and fixtures. Going to sell them on e-bay to ofset the cost of storage. The wuestion is how can I get rid of the 20+ year old gas in the saddle tank. It's rusted and really bad. I can't seem to get any of the shops to dump it in their haz-wates cans. I've got about 6 gallons of it in one gal containers sitting on the side of my house.
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 02-09-2011, 02:52 PM   #25
jbgroby
jbgroby's Avatar
Re: 61 GMC Project
You know that John Steinbeck wrote "Travels with Charlie" while driving a 3/4 Ton wideside with a custom camper see link below.
http://www.campingandrving.com/rocin...th_charley.htm
Jake
