Old 01-28-2011, 11:50 PM   #1
6084chevys
6084chevys's Avatar
265 motor oil filter need some help PLEASE!!!!!!
can some body send me a pic of where the oil filter goes on the motor and how do i run the oil line any thing would help thanx 265 motor.
6084chevys is offline   Reply With Quote
Old 01-29-2011, 01:22 AM   #2
mr48chev
mr48chev's Avatar
Re: 265 motor oil filter need some help PLEASE!!!!!!
There are some photos here that show the filter setup on a car with a 265 but I don't know if they are right for a truck.
http://inventory.bestofshowautomotiv...asp?VIN=132018
Old 01-29-2011, 01:31 AM   #3
OrrieG
OrrieG's Avatar
this should help. The filter mounts to the manifold, lines come from the block. I think the line closest to the radiator goes to the bottom of the cannister, other to the side.
http://www.67-72chevytrucks.com/vboa...d.php?t=303258
OrrieG is offline   Reply With Quote
Old 02-04-2011, 01:56 PM   #4
OrrieG
OrrieG's Avatar
I just found this in my stuff looking for something else. from the factory manual.
Old 02-04-2011, 04:24 PM   #5
Wrenchbender Ret
You confused me. The 265 is a V-8.
Wrenchbender Ret is offline   Reply With Quote
Old 02-04-2011, 04:35 PM   #6
OrrieG
OrrieG's Avatar
I assumed it was a typo.
Old 02-04-2011, 08:07 PM   #7
oldcarfart
It is same basic idea, filter mounts to engine, oil supply to filter is a tee from oil pressure sending switch (next to distributer) and oil return to an access drilled into intake manifold (in low section between runners) check the car photos in a previous response. Pressure in at top, return from bottom. IIRC oil filter was dealer add on option until '57 or '58 when GM went to cannister. Good Luck!!
oldcarfart is offline   Reply With Quote
Old 02-11-2011, 01:15 AM   #8
OrrieG
OrrieG's Avatar
I was looking at this again and wanted to point out that the diagram I posted is for an auto. On all the trucks I have seen the filter cannister is mounted on the manifold in front (bumper side) of the carb. Lines run the same.
Old 02-13-2011, 01:58 PM   #9
mr48chev
mr48chev's Avatar
No diagram but click on his gallery and he has a couple of photos of the engine with the filter sitting on it. Pretty much the same as the car 265 photo I posted earlier.
http://www.1955chevytruck.com/pictures.html Pretty nice website for the truck too and worth looking at for any Chevy truck fan.
I believe that the oil pressure fitting at the front of the block was where they ran the line to the filter from and may have been put there for that purpose at the factory. Stock intakes may already be drilled and tapped for the return line or a guy could run a line to the filler tube for a return line.
It might be a lot easier to pull the filler tube off, drill a hole in the side of it and weld in a fitting to run the line to than drilling the manifold if the manifold isn't already drilled.
Save the fourth photo from the left in the link above to your computer then blow it up on the computer and you can see the lines to and from the filter real well in the photo.
I don't think it will expand enough in this photo but one can get a good look at it.
