Old 01-28-2011, 11:58 PM   #1
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Replaced Power Steering Pump but still have same problem. Your thoughts?
I replaced my few-years-old rebuilt power steering pump with another rebuild because it quit working. It was making that familiar growling noise and was hard to steer. However, after installing the new one I still have the same issue. My dad thinks it may be a bad rebuild. Since it's such a pain to replace, I want to make sure I'm not overlooking something else and I'm wondering if there could be something wrong in the gear box that could cause the same issue. Has anyone else had this happen?
FWIW, After turning the wheel, I've noticed that the power steering fluid is foamy when I look down into the reservoir.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 01-29-2011, 12:04 AM   #2
Tmend
Tmend's Avatar
Re: Replaced Power Steering Pump but still have same problem. Your thoughts?
You might have a restriction in one of you lines or in the box if so it will make that noise steering will be hard and eventually will cause your pump to over heat and burn out.....just a suggestion............look over your system for any kinks it the metal lines or debri in the box good luck....
Tmend is offline   Reply With Quote
Old 01-29-2011, 12:04 AM   #3
STP67-72
STP67-72's Avatar
I just went through the same thing. Put new pump on and it got worse. My buddy told me right off that it was my box. Internal issues. Went and got one of my old nasty used boxes and works like a charm. My fluid was foaming and running over. I have been working on trucks forever and never ran across this. Hope this helps.
55 Chevy original swb (big back window)
61 Chevy bubble top (427-5 speed)
67 Chevy stepside (Krusty)
68 Chevy swb fleet (Lola)
68 Chevy swb fleet
71 Chevy swb fleet ( future PB project)
97 crew cab power stroke
07 SS Trail blazer
STP67-72 is offline   Reply With Quote
Old 01-29-2011, 05:17 PM   #4
1956cameo
1956cameo's Avatar
Sounds to me like the power steering gear box has gone out. If that goes out it will make even the best power steering pump useless.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 01-29-2011, 05:19 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by 1956cameo View Post
sounds to me like the power steering gear box has gone out. If that goes out it will make even the best power steering pump useless.
x 2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 03-26-2011, 10:26 PM   #6
FL71C10
Can you test a pump? Should fluid come out the line if you spin the pulley by hand?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 03-26-2011, 11:25 PM   #7
Old Yeller 1970
DON'T TREAD ON ME
As it turns out I still had air in the pump. It just took a lot, lot longer to get it all out than I thought it should. I've done this several times before and never had this kind of trouble. However, once the air was fully purged it's worked fine since then. Apparently, the air was thoroughly mixed with the fluid (the foam I mentioned in the first post) and it took a while for it to bubble out.
Old Yeller
Old 03-26-2011, 11:56 PM   #8
jerry moss
Born Psycho
jerry moss's Avatar
when you install a new p-s pump it's best to lift the front wheels off the ground and turn the steering back and forth with no weight. sometimes it takes a while for all the air to go away.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
Old 04-15-2011, 07:54 PM   #9
Old Yeller 1970
DON'T TREAD ON ME
And the saga continues.
Saturday I took Old Yeller out for a drive. Every thing was fine for the first few hours. Then I noticed the PS pump whining again. I assumed it was running low on fluid and after I got home I verified that it was empty. It had all run out. I thought it might have been a leak from the high pressure line which I'd noticed earlier was dripping a little bit. I went ahead and filled it up figuring to tighten it later. When I came back all the fluid was on the ground. When I crawled under to look at it I discovered the output shaft on the gear box and fallen out about an inch and that's were all the fluid was coming out. Whatever broke or came loose inside the gear box may have been my problem all along. I'm pulling the thing off tonight. I'll report back once I've got it apart.
Old Yeller
Old 04-15-2011, 09:25 PM   #10
Old Yeller 1970
DON'T TREAD ON ME
Now that I have it apart I can see that the output shaft hadn't fallen down. It was just the shaft seals that had fallen out. The output shaft had grooves worn in it and the seals, washers and snap ring were all bent up which means it's worn out. Looks like its time for a new PS gear box.
Old Yeller
Old 04-18-2011, 08:47 AM   #11
FL71C10
Advance Discount Auto Parts has them for $125 or $140. I got one and it looks pretty good but I haven't put it in yet.
Old 04-18-2011, 12:35 PM   #12
brad_man_72
the boat guy
brad_man_72's Avatar
time for a quick ratio box!
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-18-2011, 01:03 PM   #13
long69
just as a note: i found that i needed to have the engine running to bleed the air out of the box, every time i turned the wheels lock to lock with the engine off it would gush out the top of the pump. i don't know why this happened that way but after all the air was out it doesn't happen anymore.
long69 is offline   Reply With Quote
Old 04-18-2011, 09:23 PM   #14
Old Yeller 1970
DON'T TREAD ON ME
I ordered the Advance Auto unit Saturday for $125-$25 online coupon, $45 core charge, free shipping and $11 tax for a total outlay of $111 bucks once I turn in the core. It's a 3.5 turn quick ratio plus it comes with a life time warranty. It should be here Thursday.
Old Yeller
