67 air cleaner what is this hole for???? THANKS IN ADVANCE!!!
I NEED TO KNOW WHERE THIS HOLE GOES TO DOES THIS MEAN THE SPOUT HAS TO FACE TO THE DRIVERS SIDE/ I AM GOING TO RUN A OIL TUBE IN THE INTAKE AND THE SCRIPT VALV E COVERS WITH AN EDEWLBROK 1406 CARB
Re: 67 air cleaner what is this hole for???? THANKS IN ADVANCE!!!
to your pcv valve in valve cover
In 67 there was no emissions stuff and that is why there are no holes and the script letters for 67 and below valve covers.......
Old Skool Club
![]() Join Date: Jun 2001
No emissions stuff in '67? You're in California. I can guarantee you that CA had emissions stuff. They had PCV valves before the rest of the nation. I belive there was a plan to retrofit cars back to '55, with a PCV system to eliminate the road draft tube.
Why do you say that there was no emissions stuff on that '67 engine?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
my burb originally had emissions stuff so i know yours did. unless its not originally a cali vehicle?
Roadtrip!
![]() Join Date: Feb 2003
I am guessing someone added that. All the air cleaners i have seen of that style had no holes. I assume if you are running those valve covers you still have the down draft tube?
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Born Psycho
![]() Join Date: Feb 2001
if not, you will have oil leaks galore. by the way, cali started emissions crap in 1966-smog pumps etc.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
i say there was no emissions stuff, because 68 was the first year for the fancy stupid emissons contol stickers, 67 doesnt have it .second my stock valve covers have no holes for the stupid cr@p that was put on all the 68 87. emissions stuff including the oil that goes through the valve covers ,my engine has none of that, no holes no stupid things going in and out of the air cleaner, my valve covers done even allow the oil to go thorugh i have to get a tube that goes on the intake can any one tell me that what i said is wrong when i have my engine which is proof
you are right about one thing i need the pcv valve other wise it will blow my gaskets and seals and there fore i can have the leaking chevy did it why cant i just find out where everything goes and copy it my engine should match this one.. ![]() Last edited by 67chevy1series; 01-30-2011 at 12:39 AM. |
guys with 69 owner manuals do me a favor and look at page 43 of it and tell me what that yellow paper is and anyone ith a 67 owners manual look for anything emissions related thanks i have the manuals stated above and they as well are proof
Roadtrip!
The hole in your air cleaner would go to the valve cover. As i say, i think someone added that. Now if this is the setup you are going with on your 69 engine, you may run into problems. You will have to have the downdraft tube. I am not sure if the provision is there on a 69 block. I think you are going to have problems mixing and matching.
I should add, the engine pictured i would guess to be late 50s, early 60s...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto Last edited by too much stuff; 01-30-2011 at 12:57 AM. Reason: Add info. |
#11 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
I don't know what size engine you are running,... but the original engine should have had a "down draft tube". http://www.google.com/search?hl=en&s...wn+draft+tube+
yes i do believe those are the tubes that come out of the back of the engines right? and they point to the floor?
#13 |
Roadtrip!
You can see it in the pic you posted coming down by the starter.
#14 |
gotcha thanks eric! now any thing else i should know ? do i need to cap off that hole or plug it on my air cleaner?
#15 |
What?
BTW, that photo of the SBC is pre 67, since it has front motor mounts.
I'm guessing late 50's early 60's. Also, it has a road draft tube.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#16 |
thank you !
#17 | |
California passed the clean air act in '65,I believe. I do know Jerry Moss is an exhaust systems expert right there in California and exhaust/emissions go hand in hand. I imagine he knows what he's talking about.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-30-2011 at 07:42 AM. |
#18 |
I don't know when the actual road draft tubes were eliminated from small blocks (62?) but fittings like the one I have pictured were placed in the blocks so that a hose could be used to vent the crankcase to the intake manifold or base of the carb. This is on a 61-64 283 block, but my 64 327 block has it also. I think small journal 327 blocks had it through early 68.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#19 |
holy oil leak bat man!
#20 |
That's an old 283 I pulled from a 67 BelAir wagon I bought a few years ago out of Vegas. It
was obviously a replacement as it is a 61-64 casting. I don't want to throw it out because most of them have probably been scrapped. However, I am going to need that engine stand pretty soon so it will just have to go. I sold the wagon to a Buddy of mine after putting a 327 in it (year correct) and going through the mechanicals. It was a factory V8, three on the tree with AC, PS and PB. Wish I had kept it - it was absolutely rock solid. " ![]()
#21 |
Trucks did not get PVC til later I had a 68 impala with a smog pump. Someone may have taken that breather off a car.
69 Chevy 4x4 383 Power ![]() |
#22 |
Who's got steelies?
![]() Join Date: Feb 2006
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
#23 |
thanks for posting that link
#24 |
![]() Join Date: Nov 2001
My moms 67 Caprice 327/400 auto 4 barrel stock fully loaded came with that same set up, the fitting that rsavage is showing. It had no PVC still have the valve covers hangging on the wall, no holes. Wish I still had that motor and trans set up. My 67 283/3 on the tree also has the same set up. But the funny thing is my 67 straight 6 250 was 3 on tree but now 350 auto has the PVC. On both the V8's a rubber line come's from off the bottom of the carb to the fitting (like in rsavage pic's) on the top rear of the manifold. With the 6cyl it's from the PVC with a rubber hose to the top of the intake manifold. And as far as I can remember and may think the breather for the back pressure was through the cap on the tube on the front of the manifold were you put the new or added oil when there's no PVC. I think the down draft tube was some kind of blow by that spits some oil and smoke(EPA no no). So to capture that mess they made the set up with that fitting going to the bottom of the carb to re cycle the waste but it globbed the motor. Somewhere from there it seems they went with the PVC and going though the air filter to stop the globs and still recycle Just what I think. Nick
#25 | |
Who's got steelies?
Here are some pics of the original small block road draft tube http://www.chevytalk.org/fusionbb/sh...hp?tid/178987/ Then, in the mid 60's, some states (California) started requiring something a little cleaner, and PCV was invented. As someone stated, trucks may have not been required to have it until a few years after cars. But, we all know how easily Chevy car and truck engines and parts can be swapped around. I think the air cleaner the original poster showed is a 65-67 car air cleaner. I personally don't like to think of the PCV system as an emissions system, but as an engine cleaning system. It basically keeps the air inside the crank case clean, which helps to keeps contaminates out of the oil.
