Old 01-29-2011, 11:31 PM   #1
k1rodeoboater
dumb question about inner and outer fender replacement
Hey guys I was wondering do I need to dissasemble the whole front clip to swap the inner and outer fenders on my truck? Reason I'm asking is because I was planning on replacing my upper & lower rad hoses, and heater hoses, when I change the antifreeze.
Just trying to plan ahead so I save time and money.
k1rodeoboater is offline   Reply With Quote
Old 01-30-2011, 12:29 AM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: dumb question about inner and outer fender replacement
I know you can do the fender; done it. Not sure about the inners but I cant think of why you couldn't do it. Mite be a couple challenging bolts to get out.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-30-2011, 01:14 AM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
If you changing the upper/lower rad hoses, you dont need to remove any sheet metal. if your wanting to change the outer fenders only, you can remove them alone. If you want to replace inner fenders, you would be better off to tear it all down and start with the core suport and inner fenders, then the fenders and then the grill backer and grill. I say this because doing it this way will allow for better panel fitment and adjustments.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-30-2011, 01:34 AM   #4
kiknrocks
65 Chevy
kiknrocks's Avatar
Basically..yes to replace the inner fenders you have to take everything of even the hood.
kiknrocks is offline   Reply With Quote
