![]() Join Date: Sep 2010
69-70 GRILL question
Below, is a picture of the passenger side headlight area of my 70 with it's new "reproduction" outer grill. The other picture is of a driver's side 69 with what was said to be an "original" outer grill - my question is, did only the original 69-70 outer grills have the two bars that went all the way across from the parking light to the headlight ? Some of the people on this website have said they have original outer grills that have the bars that stop before they get to the headlight ( like my new one ). Does anyone know the REAL answer ?
. . . . Life is short . . . we only have, right now. . . . . My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526 |
Roadtrip!
![]() Join Date: Feb 2003
Re: 69-70 GRILL question
We just went through this in the last couple of weeks. I will see if i can find the thread and bring it up for you. Eric
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Roadtrip!
Go to the parts section under "parting 69 chevy" There will be some info there. Sorry, i don't know how to post links.
69s had the two bars all the way across and the 70s are like yours IIRC, also I heard the 69s ran into the 70 trucks. Hope this helps.
Name: Les ---------------------- Couple 80s Couple 70s One 68 ![]() |
I thought the 69's might have run into the 70's also - here are a couple of pictures from the dealer brochures - 69 and 70 both with the bars going all the way across.
My 70 was built in November of 1969 so maybe it qualifies as an "early" truck. This is a picture of the grill that came on my truck when I bought it in 1996 ( with dents and scratches ) The rest of the truck looked very original at that time. ( except for the ugly mirrors )
. . . . Life is short . . . we only have, right now. . . . . My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526 Last edited by Steve Hafner; 01-30-2011 at 07:33 PM. |
Tot Roddin'
From everything I have seen posted and available on the 69-70 trucks...
1969 Outer: The center lines extended past the turnsignals to the headlight bezels; only the lines were painted black 1970 Outer: The center lines extended past the turnsignals to the headlight bezels; only the lines were painted black GM Repop Outer: The center line stopped just to the outside of the turnsignals, just short of the headlight bezels. The coloring on my GM repop grill is black within the lines and between the lines on the section 'outside' the turnsignals Aftermarket Repop Outer: The center line stopped just to the outside of the turnsignals, just short of the headlight bezels. The coloring on the repop grill depends on the manufacturer; could be as described above under the GM repop or just the lines themselves. 1969 Inner: Solid 'egg crate' style all the same color 1970 Inner: 'Egg crate' style w/ recessed center sections with a mixture of silver and black coloring All GM/Repop Inner: The aftermarket and GM inners all mimic the '70 style; a '69 inner is not available from either NOS or repop
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 01-30-2011 at 06:58 PM. |
I have a 1970 c20 and it's bars go all the way to the head light. I don't know if it's original or not but my fenders were original.. I think. They are the gold poly that the cab floor and firewall are painted, which matches the build list on the inside of the glove box.
#9 | |
VA72C10
![]() Join Date: Mar 2008
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 01-30-2011 at 07:04 PM. Reason: i'm a dummy ;) |
#10 | |
Tot Roddin'
I know that the inner in my '69 in a GM replacement and it has the recessed sections which are painted silver like the '70s. Digging for another thread where we covered this same question. I will update my post... just want to find the other thread first. ![]() EDIT http://67-72chevytrucks.com/vboard/s...ill+difference http://67-72chevytrucks.com/vboard/s...=parting+chevy (Posts 19-25; Post #1 shows the '69 inner) Couldn't find the link I was looking for.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 01-30-2011 at 06:46 PM. |
VA72C10
I just noticed in the picture when blowing it up that the grille is in fact the 70 style...just not painted that way...I have always seen people say that the 70 grilles aren't reproduced and when looking at the repops they looked like simple "egg crate" style to me but obviously on closer review they have the raised portions....
So you were 100% correct and I will edit my original post to avoid confusion. Continue to live and learn! ![]() ![]() Here's pics from my old thread where I had some repro and NOS stuff for sale... note the repro inner at the bottom of the picture here (has the raised areas but painted all silver) ![]() and this was an original 70 inner painted black with the raised silver areas in it. ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 01-30-2011 at 07:09 PM. |
Tot Roddin'
Awesome post J!
Your inner NOS inner had the recessed areas, which is described in the first picture you posted as a '70. Why couldn't GM have made this easier for us? ![]()
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 01-30-2011 at 06:59 PM. |
#13 |
Tot Roddin'
See the recessed areas circled in red: (I couldn't make out the one on the far right... need glasses
![]() Sorry for the smaller picture... that's Paint for you. ![]()
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 01-30-2011 at 07:03 PM. |
#14 |
So, a 70 outer grill should have the two bars going all the way from the turn signal to the headlight bezel ?
