Old 01-30-2011, 01:48 PM   #1
bowtieboy69@yahoo.co
bowtieboy69@yahoo.co's Avatar
lmc truck door seal fit problem
has anyone ever had trouble with lmc truck door seals making the doors stick out after glued in ? after i glued my new door seals in my doors stick out about a 1inch even with my door latch assembly all the back.. my doors fit perfect with out the seals guled in but like crap with them in.... any sugestions ? should i get new ones from some where else or try to find some origionals that r in good condition ? thanks
bowtieboy69@yahoo.co is offline   Reply With Quote
Old 01-30-2011, 03:10 PM   #2
Fldawg
Fldawg's Avatar
Re: lmc truck door seal fit problem
had the same probelm, theres something about the rubber they use, try a set of softseal door rubbers, but also when you put them in keep the doors shut for a couple of days and in the sun. see if that works , the soft seal rubbers are about $69 double what you paid at lmc, but i think that will solve your probelm
Fldawg is offline   Reply With Quote
Old 01-30-2011, 04:10 PM   #3
thanks for the reply ! ive had my doors strapped for 3 months while ive been at college and it hasnt seemed to change these lmc truck seals one bit lol.... so where can i buy a set of softseal door rubbers at ?
Old 01-30-2011, 04:12 PM   #4
Fldawg
Fldawg's Avatar
softseal.com
Old 01-30-2011, 04:33 PM   #5
thanks for the reply ! i think this is what i will try next.
Old 01-30-2011, 05:30 PM   #6
Fldawg
Fldawg's Avatar
it's gonna help if the temp outside is warm, with you being in nebraska i don't think it has been warm for awhile, but do what softseal recommends
Old 01-30-2011, 05:49 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
also consider the ones GMC pauls's sells. They are a press on style...not glue in.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-23-2011, 09:46 AM   #8
mikewarme
Yes the press on type from GMC pauls r nice if you don't mind the upper front corner not covering all the way.
mikewarme is offline   Reply With Quote
Old 06-23-2011, 06:36 PM   #9
mbgmike
we sell the press on ones as well. same manufacturer just for info
mbgmike is offline   Reply With Quote
Old 06-24-2011, 01:26 PM   #10
leddzepp
Moderator
leddzepp's Avatar
This is the ONLY way to fly...
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
