Additude Adjustment
Did some work on the truck this weekend. DJM 3/5 drop anf 20/10 Boss 338 on the rear and 18/8 on the front. Tires came off My vette so I had to buy some adaptors for the different lug pattern. Im still thinking of maybe putting in a set of 1" drop springs on the front. What do yall think? Oh and some thicker tires.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
yeller
Re: Additude Adjustment
Looks good, YES, 1 more inch in front, maybe 1.5 even.
A rear sport bumper and OEM tail lights will make it look even better. ![]()
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 01-30-2011 at 02:37 PM. |
6.0 powered square
looks good I'd say chop a coil off the factory coils and see where your at
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#4 | |
It followed me home?
looks good!
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
#5 | |
The One And Only !!!
^^^^^ Same here, Looks great with those tires !
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
#6 | |
I thought about cutting the spring but 1" springs are cheap enough and if im gonna put the effort into pulling the 25 year old springs out i might as well put some new ones in. I had to do a slight toe adjustment so an alighnment is on the list too. Man the list never ends does it!! LOL
just drop it more an the tires will look perfect!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Looks good!
VA72C10
![]() Join Date: Mar 2008
Looking good. Yes, I agree eventually on some taller rubber and the drop coil...I'd measure compared to stock on the front. Might want to do a 2" coil as the factory coil might already have sagged close to an inch...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Happy to be here
![]() Join Date: Mar 2000
Wow! That looks sooo good. I like all your plans, except the front end swap.
Posted via Mobile Device |
#11 | |
Thanks for all the compliments everyone. This took me longer this weekend than i figured it would have cause i had to replace all 4 ball joints. But if your in there you might as well do it right while its apart. Ya know.
Parts and more parts
this is the son's truck. We are working on getting the Boss wheels mounted. I finally have the whole mess figured out and the center caps are of no problem either.
Frank |
#13 |
Nice!! I wished my paint looked that good. My center caps would not be an issue if I could find them LOL. I put them in a box before i moved and have no idea where they are now. I only have the 1" rotors so not a big deal with them regardless but since they were the small chevy corvette bolt pattern I had to use adaptors which also made it not problem. Eventually im putting in a narrowed rear end with an IFS coil over front and will be going with a set of Coys more than likely. But till I have the fundage for that I made due with what I had laying around the house. Gotta find some center caps though. I ordered some from the Boss or American Wheels whatever their name is but when they didnt show up for a couple weeks I had to call and ask about them only to find out they cancelled my order cause they didnt have any in stock and they were backordered.
#14 |
We have the 1.25" rotors, but I put on a 1/4" spacer and longer front studs. I also ground down the front hub's metal where the dust cap fits. There is plenty of room now.
Summit racing shows that they have the center caps on hand.
Frank Last edited by piecesparts; 01-30-2011 at 08:11 PM. |
#15 |
I looked at that too but it also says they ship from the factory on them. Ill probably order from them with a few other things when I get some more fundage. Trying to find some locally first though.
#16 |
Happy to be here
That front end combo is not that common, so I would leave it. An old member here called Swervin Ervin had a white truck with the same front end. It really stood out from the others.
#17 |
HMM interesting thought. I figured there were tons of them since it was a base model option for these trucks.
#18 |
I like it! The front end you have looks good. But I have to agree with others on the rear bumper and tail lights. A tucked in sport bumper would look killer.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#19 | |
VERY clean and good looking truck
2004 Silverado Crewcab (Dark Spiral Gray) |
#20 |
I'm in agreement with the tail lights. They were on there when i got the truck and they work so that's kind of a bottom of the list thing. I need to go to the pull a part in Memphis to see what I can find down there. I need a sway bar for the front and a instrument panel with the silver layer on it. My temp gauge is broke so I figured I would just get the fancier one maybe with a tac if i can find it.
