01-30-2011, 02:30 PM | #1 |
Carb Return Spring
A friend rebuilt my carb and I was going to replace the return spring so it looks more presentable. Is there supposed to be a simple hook on the end of the spring that I've circled? I suppose I could find a "universal" spring that fits and use that. Thanks.
1972 GMC 2500 Custom, 96K miles, Purchased New By My Grandparents 2016 Toyota Tundra TRD Off-Road SR5 1993/2003/2005 Toyota Land Cruisers 2004 Corvette Z06 / 2000 Covette Coupe 2006 Ducati Multistrada 2014 BMW X3 XDrive35i M Sport |
01-30-2011, 03:02 PM | #2 |
Re: Carb Return Spring
you have your PVC and breather hoses reversed the PVC goes to carb the breather to the air filter spacer
i just use hardware store springs or for lookin good the boatstore has ones that dont rust as fast
01-30-2011, 03:17 PM | #3 |
It'll Buff Out!
The return spring is connected wrong. I might have a pic
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB Last edited by So.Cal.Super; 01-30-2011 at 03:19 PM. |
01-30-2011, 03:27 PM | #4 |
Who's got steelies?
Here you go:
He's got the hoses right. It just doesn't look that way because of the heat stove pipe, and oil fill extension.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel Last edited by oldgold70c10; 01-30-2011 at 03:34 PM. Reason: Added Picture |
01-30-2011, 03:33 PM | #5 |
The part of the spring in the circle? If so, that's what I'm trying to fix.
I took photos of the carb, etc. before I took it apart so if it's hooked up wrong, Grandpa had it hooked up wrong. Let me know if you have a photo I can take a look at.
01-30-2011, 03:39 PM | #6 |
It'll Buff Out!
here is a pic of the springs and my pcv hoses. I have a breather instead of to the air cleaner. Oldgold nailed it, I was confuesed by the oil fill ext also
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
01-30-2011, 03:39 PM | #7 |
It'll Buff Out!
beat me on pics also
01-30-2011, 03:41 PM | #8 |
It'll Buff Out!
Although I have a Dual spring it is still a Soft spring, making my pedal very soft to the touch. I got mine from a carb shop. Not sure what you will find at Home Depot or a Boat yard. I've always been told the harder the spring the more the throttle bushing will just wear faster.
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB Last edited by So.Cal.Super; 01-30-2011 at 03:42 PM. Reason: grammer |
01-30-2011, 03:49 PM | #9 |
Interesting...I've got the spring in your photo as well. Looks like you don't have the smaller, longer spring that I've got on the front of the linkage. Can somebody clarify if the spring I've got circled in my original post is factory? I'm beginning to think I can just remove it.
Thanks. Pre-carb rebuild pic as I was taking the linkage apart:
1972 GMC 2500 Custom, 96K miles, Purchased New By My Grandparents 2016 Toyota Tundra TRD Off-Road SR5 1993/2003/2005 Toyota Land Cruisers 2004 Corvette Z06 / 2000 Covette Coupe 2006 Ducati Multistrada 2014 BMW X3 XDrive35i M Sport Last edited by harrydunn; 01-30-2011 at 03:52 PM. |
01-30-2011, 04:22 PM | #10 |
It'll Buff Out!
I have never seen one factory with that front spring. my service manual doesn't show it either.
01-30-2011, 04:39 PM | #11 |
Off it comes...
01-30-2011, 04:44 PM | #12 |
Who's got steelies?
You say you have that spring AND the stock location spring? You might want to investigate why the second spring was put on. Maybe something is binding somewhere and the one spring wasn't enough?
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel Last edited by oldgold70c10; 01-30-2011 at 04:44 PM. |
02-11-2011, 12:12 AM | #13 |
Ha, you nailed it! Drove the truck home from my brother's house this evening where we had been working on it for about a month. Found it odd that it would never kick off of high idle at stop signs, etc. and then it dawned on me that I had removed that spring. I wonder if perhaps the factory spring has lost it's ability to return the throttle linkage?
02-11-2011, 12:24 AM | #14 |
Junior Member
O'Rielly's has carb springs in the help section, if I remember right.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
02-11-2011, 10:16 PM | #15 |
Picked up a dual spring tonight. Going to install it tomorrow and see what we get. I'm assuming the dual spring is just a safety measure?
02-12-2011, 02:03 AM | #16 |
Gettin It One Pice At A Time
Stay away from chrome ones, brittle central. And yes it's a safety thing. The dual spring are usually with one lighter and one stiffer.
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
02-12-2011, 02:17 AM | #17 |
yes, i do
FWIW, i have used the chrome ones and never had an issue. with the double springs that i have bought i generally just use one cause i find that the double spring is just too stiff. i do keep an extra set of springs just in case the one i have on there breaks
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
