Old 01-30-2011, 02:39 PM   #1
1972k5blazer
pedal assembly help?
I got a brake pedal assembly for a auto can i add a clutch pedal to this assembly or do i gotta get a whole new unit ? Sorry if its a dumb question got a stripped 69 trying to figure some things out to have all the right parts when it goes back together . thanks
1972k5blazer is offline   Reply With Quote
Old 01-30-2011, 04:41 PM   #2
OldCreek
OldCreek's Avatar
Re: pedal assembly help?
The setup replaces as a whole unit. There's at least one for sale on the parts board right now...cheap too.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 01-30-2011, 08:22 PM   #3
1972k5blazer
Thank you ! Ill look at it
Old 01-30-2011, 10:34 PM   #4
Critter
Future TOTM Winner
Critter's Avatar
You can simply ADD the clutch parts to your auto set up if you want. They are the same from the factory, the auto setup is just missing the clutch petal and shaft. I can get a picture of both side by side if you need it.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-30-2011, 10:36 PM   #5
OldCreek
OldCreek's Avatar
Cool. I didn't know that.
Btw, there is just a clutch pedal for sale on the parts board, too.
Old 01-30-2011, 10:46 PM   #6
1972k5blazer
could you please do that so ill know what parts to get . I thought it looked like it had a spot to hang a pedal but thought i should ask someone who would know .
Old 01-30-2011, 11:51 PM   #7
Critter
Future TOTM Winner
Critter's Avatar
The first 2 pics are of my factory 72 auto setup. Notice the tube running left to right through the middle of it. The 3rd, 4th and 5th are of a complete clutch setup I bought from TEEITUP. You can see that the main bracket is the same along with the brake pedal parts. The difference is the clutch pedal and "shaft" that run left to right through the housing and eventually move the lever on the far right side. This is where your clutch linkage would connect and run through the firewall and down to the pivot on the frame. I removed the clutch pedal from a 68 truck years ago and it was pretty straight forward if I remember right. It isn't too hard to find someone that is swapping from manual to auto and most of the time they will remove just the clutch parts mentioned. Find that person, buy the parts from them, then put them in your factory auto housing. Basically you need the clutch pedal, the shaft, the lever on the right, and I think there is a bearing on each side of the tube but I can't remember for sure. Hope this helps.
Old 01-31-2011, 12:22 AM   #8
1972k5blazer
Sure did ! Thanks alot
Old 01-31-2011, 12:43 AM   #9
maynardtruckin
maynardtruckin's Avatar
There is two plastic bushings on ether side of the tube but can be installed in the truck or out of the truck.
Chris
67 c10 swb build in progress
70 c10 lwb driver pending parts for drastic overhaul
70 c20 lwb parts truck for above mentioned drastic overhaul
71 k20 lwb building for off road use and towing
maynardtruckin is offline   Reply With Quote
Old 01-31-2011, 12:46 AM   #10
Critter
Future TOTM Winner
Critter's Avatar
Yeah bushings sounds right now that you say it, not bearings. Thanks for making that correction.
Old 06-12-2011, 07:40 PM   #11
schurg
I'd like to ressurect this post. I have a manual truck with a auto trans. from what I'm reading above, I should be able to just remove the clutch pedal? it seems the axle the clutch pedal and brake rotate on is pressed in. how does one go about removing the pedal?
schurg is offline   Reply With Quote
Old 06-15-2011, 06:13 AM   #12
BlazinC5
BlazinC5's Avatar
Here is another question I didn't see answered. Are 67-72 clutch pedal assemblys all the same or were there changes between those years?
71 2wd Blazer
My build, Restarted
05 Buell firebolt
94 1500 Z71
No rice for me,,, I'm full
BlazinC5 is offline   Reply With Quote
Old 06-16-2011, 05:10 PM   #13
roadking-111
roadking-111's Avatar
I'm in the same situation...... any help from the board?
roadking-111 is offline   Reply With Quote
Old 06-16-2011, 05:24 PM   #14
roadking-111
Hey schurg....I found a couple of threads that should shed some light.
http://67-72chevytrucks.com/vboard/s...g+clutch+pedal
Old 07-05-2011, 12:04 AM   #15
schurg
perfect! thanks roadking
Old 06-01-2017, 08:54 PM   #16
Nick2x2x
Nick2x2x's Avatar
So basically the spacing is the same for auto to standard? I'm looking to remove my clutch pedal since I'm going to an auto
Nick2x2x is offline   Reply With Quote
