Old 01-30-2011, 03:09 PM   #1
yellow70
yellow70's Avatar
Question Gears ?
Hi, new to game of rebuilding a Blazer. How do i find out what gears are in the front of my 71 blazer without opening it? The guy i bought from said the rear had been changed. Thanks
yellow70 is offline   Reply With Quote
Old 01-30-2011, 07:44 PM   #2
Mike C
Mike C's Avatar
Re: Gears ?
Unless some previous owner took it off and tossed it, there should be a metal tag on the front diff underneath two of the cover bolts showing what the front ratio is. Usually it is covered in grease, so spray around the cover with carb cleaner and a brush. If it is missing, this would be a good opportunity to change the fluid in the front. Was the rear rebuilt or was the ratio changed? Either way, I would want to know for sure. I have a K30 with a Dana 60 front that the tag is gone off of. The front driveshaft was out when I got the truck, and someone has drawn a line through the 3.73 on the SPID and written in 4.10. All of these things are red flags to me, so both covers are going to have to come off to figure out exactly what some PO has jacked with.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-31-2011, 12:44 AM   #3
Critter
Future TOTM Winner
Critter's Avatar
Re: Gears ?
Originally Posted by Mike C View Post
...All of these things are red flags to me, so both covers are going to have to come off to figure out exactly what some PO has jacked with.
I agree. Just pull the cover and count the teeth, it's the best way to be 100% sure. Besides, I'm sure that axle could use some fresh gear oil anyway.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-31-2011, 07:38 AM   #4
Blazer1970
Blazer1970's Avatar
Re: Gears ?
If it came with a 350, it came with 3.07 gears. If it came with a 6 cyl. or a 307, it came with 3.73 gears. Any other ratio would be listed on the SPID.
Blazer1970 is offline   Reply With Quote
Old 01-31-2011, 10:04 PM   #5
NW_Ryker
Re: Gears ?
My blazer with a 350 came with 3.73 gears. If he changed the gearing in the back and not the front he would've blown his t-case right?
NW_Ryker is offline   Reply With Quote
Old 01-31-2011, 11:44 PM   #6
yellow70
yellow70's Avatar
Re: Gears ?
My blazer with a 350 came with 3.73 gears. If he changed the gearing in the back and not the front he would've blown his t-case right? I hope not!!
Old 01-31-2011, 11:47 PM   #7
yellow70
yellow70's Avatar
Re: Gears ?
Tim Thanks!
