01-30-2011, 03:49 PM | #1 |
double transfer cases
I'm thinking about making a 205/203 double setup because A 203 can be had around here for about 25 bucks. (literally, I couldn't give mine away) And I'm Thinking that not only will i get lower gears but wouldn't it also give me higher gears for the highway? Does anyone have one of these setups and do you like them, And do they bring the rpms down on the highway quite a bit? I'm just looking basically for anyone that has one to tell me what you think of it Please. Much appreciated.
01-30-2011, 04:40 PM | #2 |
Re: double transfer cases
I'm pretty sure you will not get higher highway gears. I think the adapters to mate these are fairly expensive so make sure you "need" this setup.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
01-30-2011, 05:04 PM | #3 |
Ok I just thought since when you put them both in lower it doubles the ratio so the same would go for both in high? And maybe bring the rpms down a bit. Of course I don't need this setup but I'm bored with a tax return and wanna build something. lol. I also just remembered finding a 203 with a 10 spline input shaft would be kinda tricky.
01-30-2011, 11:14 PM | #4 | |
Future TOTM Winner
Also, look here
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 01-30-2011 at 11:31 PM. |
01-31-2011, 04:06 PM | #5 |
Yeah I looked on ORDs website and there is way more things that I didn't Think about. I have a couple 203s and 205s but none are the correct ones, and quite a bit more modification would be necessary and more exspensive than i thought. Still would be cool to have one though
01-31-2011, 04:23 PM | #6 | |
nickle and dime |
01-30-2011, 09:12 PM | #7 |
20' Daredevil (Ret)
Yes, I believe high range is direct 1:1 ratio in both. Double cases gives more gear reduction in low-low but nothing above 1:1 in high.
01-30-2011, 05:35 PM | #8 |
Running a doubler is mainly for offroading reasons. It gives you a lower crawling ratio. It's not going to cut down on the rpms in your truck while driving around town.
1987 gmc sierra v1500. 350 tbi, 700r4, 6" sky jacker lift, 15" Mickey Thompson wheels, and 35" bf Goodrich km2 tires. |
01-30-2011, 05:50 PM | #9 |
gets board easy.......
i want to do if but dont have the $$ for adaptor and $$ for shafts at this time and i think there is some $$ for shifters and some $$ and time for crossmember modification
01-30-2011, 06:12 PM | #10 |
I know its mainly for offroad which I do quite a bit of. Does anyone have one of these?
02-01-2011, 04:35 AM | #11 | |
http://lasvegas.craigslist.org/pts/2157712852.html
1968 K10/30 Frame Off Project "Overkill" My 5 year, $30,000.00 toy |
02-01-2011, 02:00 PM | #12 |
Thanks I'll check it out and see if maybe he'll seperate it
01-30-2011, 06:15 PM | #13 |
If you want to get some really good info, go to ck5.com or pirate4x4.com. Both of those sites will have all of the info that you want/need for putting a doubler in your 4x4. Also, Off road design sells all the parts required to install one in our trucks.
01-30-2011, 07:27 PM | #14 |
Ok thanks for the link
01-30-2011, 10:42 PM | #15 |
Stocker is right. 1:1 and 1:1 is still.... 1:1. In low you will have 2:1 reduction (205 only) and 4:1 (203 range box and 205 in low). Big bucks. I'd love one. www.offroaddesign.com has lots of info. As mentioned, drive shafts, cross members, shifters, likely exhaust work...
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
