72 GMC 4x4 4speed Suburban big block
Having issues putting big block in and clearing linkage any suggestions on manifolds or headers that work :gmc2
member
Re: 72 GMC 4x4 4speed Suburban big block
Have you started by installing big block motor mounts? If so you should be able to change to any factory truck big block only parts.
John
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
Big block mounts were not offered in 4x4 67 to 72 models
member
Sorry for confusing your thread. I KNEW THAT! My brain must have skipped a beat.
Here's my problem would like to install headers for my 454 to clear frame but they wont clear my linkage for clutch have you or anyone on here had this issue and how do I over come it without going automatic there not much room with the 4x4 transfercase on a 4 speed
6>8 Plugless........
![]() Join Date: Sep 2007
I put a 396 in my 70 3/4 ton 4x4 and I ended up using headers for 73 up 2wd trucks with BBC's in them. You might have good luck with a chevelle header too.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Junior Member
I believe hooker makes a app for it,its been years but had a 69 with a bb 4 spd set up.they were expensive but fit real nice.
![]() Join Date: Nov 2005
I did this same set up on a 71 4x4 3/4 PU. I used stock manifolds. The trick is the bracket for the Z bar. Chevy had a special bracket that mounted to the engine. Look it up in the old parts manuels. I found one off a big block 4spd 2wd and it worked fine. Caution though. This part is hard to find and unless you see one on a truck it won't make since to ya. It's weird but it works.
