Old 03-13-2003, 07:37 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
Q about 67-68 seats
Just picked up another set of 67-68 bucket seats. On one set , the drivers side is stationary and the pass side adjustable. On the other set it is opposite. Both sets have original coverings, but different patterns in the coverings (very similar tho) Question is, is 67 different from 68? and why adjustable opposite each other?
too much stuff is offline   Reply With Quote
Old 03-13-2003, 08:06 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
The vinyl pleating is different between 67 and 68. As for the rh adjustable seat, does the adjustment mechanism look identical to the LH one that we're familiar with? If so, 2 possible scenerios come to mind:
1. Out of a RH drive truck? I suppose this is possible.
2. Someone found a similar GM setup out of a car and swapped brackets on the RH side for some odd reason.
If the adjuster is totally different, then maybe it;s someones hack job? I don't think swapping seats would work as adjuster would be on center side of passenger seat if that were the case.
Got pics?
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
