01-30-2011, 10:08 PM | #1 |
Dirty Dirty Tranny
Well, I'm getting closer to going automatic - just have to do some cleaning and such. I'm pretty sure there's a transmission under there somewhere. The only clean part is the tag!
Can anyone explain the extra steel welded on the flex plate (ring gear or what ever we want to call it today). It sits up pretty high and is actually stamped with a number. Does this mean it was perhaps balanced to the crank shaft and harmonic balancer on the other end? Any and all input is greatly appreciated.... and I'm taking donations of elbow grease!
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
01-30-2011, 10:09 PM | #2 |
Re: Dirty Dirty Tranny
couple more
01-30-2011, 10:11 PM | #3 |
Dave's not here, man
Is that not the weight that keeps it in balance? That thing sure is filthy. You will have to be sure and post some "after" pics once you get it all cleaned up.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 01-30-2011 at 10:17 PM. |
01-30-2011, 11:59 PM | #4 |
Make sure that the flex plate isn't for a 400 small block which I believe used an externally balanced flex plate. I don't think my flex plate had any balance weights on it.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
01-31-2011, 12:03 AM | #5 |
don't over look that it may be from a 454
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
01-31-2011, 07:17 AM | #6 |
My bad - it is from a 454 - is there some significance to that?
01-31-2011, 10:37 AM | #7 |
the 454 was externally balanced.The flex plate and harmonic balancer were used to get it to run smooth, if you use one of them on a internaly balanced motor it will shake.I bet it would come apart sooner than later aswell.
01-31-2011, 12:12 PM | #8 |
It's a close call, but mine may have been worse than yours. A little elbow grease and she'll look brand new.
72 Cheyenne Super 80 Silverado Blazer 2wd |
01-31-2011, 01:26 PM | #9 |
wow that is filthy, now that is one reason I decided to repaint and clean up everything under my truck to a restored finish. LOL got tired of crawling under it to work and get nothing but dirt and grease in my face. GL Cleaning that thing or finding that leak.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
01-31-2011, 01:32 PM | #10 | |
Correct he is. You can knock the weight off if you want to or replace the flex plate and sell that one to a person who needs it. If you have a 383 stroker, 400 or 454 you need the counterweight though. |
01-31-2011, 05:15 PM | #11 |
OK - I have the 454, T400, torque converter, flex plate, harmonic balancer and yoke to go from the tranny to the drive shaft. The motor is partly rebuilt (top end not done yet). The balancer rubber looks bad. When I get a new balancer, do I have to put the flex plate on in any special direction/order or rebalance anything? The whole setup is out of a 73 elky SS.
01-31-2011, 05:50 PM | #12 |
I am a Referee of life.
IIRC there is a locating pin that only allows you to bolt the flex plate up one way.It should go thru a hole located midway or so between bolt holes.It's been a while but that's what I remember.
BTW an hour or so with a scraper,a couple dousings with a good degreaser and I'll bet you find a tranny under there(and I don't mean a man in womens clothing).Take it to the carwash along with some degreaser to do that part.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 01-31-2011 at 05:52 PM. |
01-31-2011, 06:28 PM | #13 |
I hit it with a scraper this morning, then dragged out all the hoses, set up the pressure washer and started making progress. The washer bogged and I smelled electrical burning... smoked the danged pressure washer.. ugh! Sooooo, I was thinking of hitting it with some easy off... can't find that either... just having one of those days!
02-01-2011, 10:14 AM | #14 |
Bleche-White is your friend. We use it to clean up stuff all the time. It cuts the dirt and grease pretty quick.
02-01-2011, 02:55 PM | #15 |
You never know what you could find
1969 Chevy c20(Miss Hackjob) |
