Old 01-30-2011, 10:36 PM   #1
Backcountry_builder
clarifing disk brake swap?'s
I have a 1968 c30 that I would like to put disk brakes on the front of. I also have a 1993 c3500 dually for parts. From reading about the 6 lug disk brake swap I figure that I can put the spindles from the 93 on my 68. Is this a sound idea or is it not going to work? Also am I correct in my understanding that I can install the 14 bolt from the 1993 with out modifying the perches?
Backcountry_builder is offline   Reply With Quote
Old 01-31-2011, 11:23 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: clarifing disk brake swap?'s
Sorry I can't answer your questions.
I would think the 73-87 C30 trucks would be better donors for disc brake parts.
Keith
Convert to disc brakes.
Old 02-02-2011, 07:27 PM   #3
Backcountry_builder
after reading about it I would have to agree, but I own the 1993 parts trucks so I would like to use it if I could. If nobody knows I guess I will be the test mule.
Old 10-24-2011, 06:01 PM   #4
fishnixon
fishnixon's Avatar
Any info regarding this...how'd you do with the 14 bolt? Thanks
Rob
fishnixon is offline   Reply With Quote
Old 10-25-2011, 12:04 AM   #5
andrewmp6
I don't have a clue but measure the spring perches on both axles see if they are the same.
andrewmp6 is offline   Reply With Quote
Old 10-25-2011, 08:28 AM   #6
Tony@AirRideTech
Junior Member
The front will not "swap" straight out.... you would want to use 73-87 (73-91 Crew cab) C30 for a direct swap. In the rear I doubt that the axle perches are where they need to be however, cutting those off and welding them back on in the correct spot is not a big deal at all.
Tony@AirRideTech is offline   Reply With Quote
