01-31-2011, 12:24 AM | #1 |
How can I tell what...
year model front suspension/brake sytem I have on this truck? I can't get the brakes to bleed so I have surmised that the master cylinder must be bad, but I cannot figure out what the proper master cylinder for it is. Is there something I look at to see what year model it is? It is 5 lug and disc up front, other than that, I don't know what else to look for. I have attached some pictures to see if anyone can id this master cylinder.
70 SWB 454/TH400 |
01-31-2011, 12:27 AM | #2 |
Re: How can I tell what...
looks exacltly like the one on my 72 i would just take it in to the parts store and start opening boxes. good luck
01-31-2011, 12:37 AM | #3 |
I guess I should have told you, that I did that today for a while. The parts guy checked 69 through about 80 and none seemed to match up. I thought that the previous owner told me that he had converted the front end to a mid 70's but the master cylinder the parts guy showed me did not seem to match.
70 SWB 454/TH400 |
01-31-2011, 12:41 AM | #4 |
As long as the hole in the back is the same depth and the line fitting are the same size they are pretty universal
01-31-2011, 12:41 AM | #5 |
its all about the +6 inches
Go and ask your parts guy if a 73 - 77 is the same P/N. That would cover "mid 70's", and I'll bet they are all the same. Yours may not be the same brand as what your parts guy has.
01-31-2011, 01:10 AM | #6 |
It looks exactly like this one http://www.napaonline.com/Search/Det...+50014+2014024
Which has a 1-1/4 bore and fits a 71 C-10 along with others. As 1low said, check the depth of the hole in the piston to be sure they are the sa^^e. |
01-31-2011, 01:41 AM | #7 |
Does the one you parts guy has look like any of these? Like stated earlier, I think there are several styles that could be used. Your parts store probably only offers one style.
72 Cheyenne Super 80 Silverado Blazer 2wd |
01-31-2011, 01:42 AM | #8 |
The one pic in your original post is the one I have seen most often.
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 01-31-2011 at 01:45 AM. |
02-01-2011, 12:53 AM | #9 |
As usual you guys were correct. Napa had the correct one for a 72. They had a couple different models for the same year model. Thanks again.
70 SWB 454/TH400 |
02-01-2011, 01:28 AM | #10 |
Registered Chevy Owner
I had to find a new gasket for mine like that one. Talk about a pain.....turned out the only one that fit was a f@&d part number... Those master cylinders are for our trucks right?
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
