Old 01-31-2011, 07:24 AM   #1
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
where to cut the frame to make a long wheel base to a short wheel base?
i will be doing this soon and was wondering if anyone has done this and can recommend where to cut the frame i thought the show Trucks!!! on Spike did it and i cant find the video any way any help would be awesome!!thanks
gostranger is offline   Reply With Quote
Old 01-31-2011, 08:37 AM   #2
helipirate
helipirate's Avatar
Re: where to cut the frame to make a long wheel base to a short wheel base?
Trucks! did do a show on it. You can watch it on demand here http://www.amazon.com/gp/product/B000RCNPIA http://www.amazon.com/gp/product/B000RCNPIA
Classic Trucks did it here
http://www.classictrucks.com/tech/cl...uck/index.html
Early Classic did it here
http://www.earlyclassic.com/tech.asp...20No!-Shortbed
There is a few threads on it and members that did it on the forum too, the articles and video show you where and how much to cut. Some of them cut in different areas but they all take a total of 20 inches out of the frame. 8 right off the back and 12 usually under the cab where the frame rails are straight.
helipirate is offline   Reply With Quote
Old 01-31-2011, 10:18 AM   #3
gostranger
gostranger's Avatar
thanks that is what i was looking for time to warm up the sawsall!!!
Old 01-31-2011, 10:37 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Check our FAQ forum. There are a couple of well written articles there too.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-31-2011, 03:18 PM   #5
lucifer
lucifer's Avatar
Cool Re: where to cut the frame to make a long wheel base to a short wheel base?
When I cut mine I tok 12 inches out ahead of the rear cab mount (mover cab mounty back 12 inches) and then took 6 inches off teh rear of the frame.
I chose to make the cut ahead of the rear cab mount because the frame is uniform and straight at that point. Put in an 18 inch plate on teh inside of teh frame to form a box frame centered over the cut. Left the crossmember in place and put in a one peice driveshaft. Made for a very easy job and great result.
regards
Luc
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 01-31-2011, 04:43 PM   #6
kieth
kieth's Avatar
I just went out and found a rolling swb frame, took all the stuff of the lwb and put it on the swb,,,,,,much less work......cost $175.00 also got a complete front clip, cab with doors, and a fleetside be with tailgate.....Kieth
kieth is offline   Reply With Quote
Old 01-31-2011, 06:37 PM   #7
SCOTI
SCOTI's Avatar
What he said....
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-31-2011, 10:02 PM   #8
gostranger
gostranger's Avatar
awesome thanks for all of the info from everyone!!!!!
