01-31-2011, 09:15 AM | #1 |
Fan selection comments
I have to go with a mechanical fan for my 383. I have the appropiate shroud but would you go with a flexilite fan or one with a clutch as original? I purchased the Brothers dual electric fan set up and with my setup, it does not fit betweeen the engine pulleys and radiator.
01-31-2011, 10:28 AM | #2 |
Re: Fan selection comments
Perhaps a poor suggestion, but maybe swap out the tall water pump (if that's what you have) and put in a short wp. That may give you the room for your elec. fans.
71 GMC 1500 LWB |
01-31-2011, 10:53 AM | #3 |
Junior Member
I have found for the set-up in my '71 with a '73 454 the stock clutch fan setup works best.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
01-31-2011, 11:25 AM | #4 |
I went to the boneyard, and got a fan assembly from a '98 Caddy DeVille. Pretty good fit -- had to bend up some sheet metal for top and bottom brakets-- but it's great. One fan works with the ignition, and the other comes on when the a/c compressor comes on. If no a/c, then get a water temp switch that comes on at a speciffic temp. This unit takes up very little room. Good luck, Norm
01-31-2011, 11:34 AM | #5 |
What is the distance between the outer most pulley and the radiator?
01-31-2011, 11:48 AM | #6 |
i always used the stock fan/clutch setup... worked great...
https://www.ebay.com/itm/29620574751...mis&media=COPY |
01-31-2011, 12:25 PM | #7 |
20' Daredevil (Ret)
My one experience with a flex fan went badly, with overheating problems. I put a clutch fan back on and have not overheated again.
01-31-2011, 01:20 PM | #8 |
I have a 383 also and used an electric fan. what I did was mount my fan on the inside of the radiator shroud with some spacers to push it in closer to the radiator. but as seeing you said you purchased a dual setup It may not work the same
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 Last edited by Jeffs70; 01-31-2011 at 01:21 PM. |
01-31-2011, 02:51 PM | #9 |
i got lucky....replaced the dinky stock 2 blade fan on my 72 burb c20 with the 7 blade unit off my dad's old 72 burb c10 that had hd cooling and a/c. it fit the fan shroud, looks stock and pulls plenty of air through that 4 core radiator i installed.
01-31-2011, 03:24 PM | #10 |
I use the short w/p with dual electric fans controlled by a toggle switch in the cab,, never once had an overheating problem
02-02-2011, 05:04 PM | #11 |
I checked, and from the radiator core surface to the the outside surface of the fan assembly(closest to the engine) is 4 inches. You will have a lot more room than mine, because I moved the entire engine/trans/transfer case assembly forward, about 1 3/4 inches. This was to accomodate the 700R4, without shortening the rear driveshaft, and lengthening the front one. I also changed over to serpentine setup, from a '91 chevy wagon. Let me know if you want some pix, and I can send them to your email. Norm
