C35 Crew Dually
C30 question.
I just ordered the shackle an hanger set for my c30 but can see to find any pics of a c30 with it installe can anyone help?
my suspention is going to be 3 inch drop spindals in the front cut 1 maby 2 coils in the front and shackle and hanger set in the rear. just want a rough idea what it will look like. Thanks.
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
It followed me home?
Re: C30 question.
I've got some pics of my old fleetside but I think you are probably looking for dually pics right? I think pigrig is lowered with hangers, shackles and overload removed. Might check under his user name
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
#3 | |
C35 Crew Dually
Re: C30 question.
lol
Re: C30 question.
yep mine is 3" spindles and 1" spring and shackle hanger out back
the slope of the driveway makes it look like it has more rake then it realy does
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
Re: C30 question.
Do you think you would be able to clear those tires in front with a full 6" of drop?
C35 Crew Dually
Re: C30 question.
Pig you don't happen to have a pic of your truck lowered with stock wheels do you? or ar those roughly the same hight as stock rims an tires?
Forgot (thanks for the fast responce)
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 Last edited by 1tonchevy; 01-31-2011 at 04:51 PM. |
#7 | ||
Re: C30 question.
hope that helps just thought if you look at this other one of mine its got 225/70/16(I'm thinking) and a 4" drop in the front hey I think I lied I know its a bad picture but I think it was taken after I got the great Idea to cut a coil off the 1"drop spring
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG Last edited by pig rig; 01-31-2011 at 10:30 PM. |
#8 | |
C35 Crew Dually
Re: C30 question.
Also how many coils would be ok to cut out of stock springs? i have read 1,1 1/2 and 2 inch.i was thinking maby 1 1/2 to go with my drop spindals?
Re: C30 question.
I'd start with one
#10 | |
Re: C30 question.
I cut 1-1/2 out of mine
C35 Crew Dually
Re: C30 question.
Also. Did you take anything out of the back leaf wise? or you running completly stock? only reason i was is i'm running 6 rear leafs. and no over load as i will nere be towing anyhting
Re: C30 question.
on my black one no I didnt
on the black and purple one its got a funky set up under the rear that keeps a rearend under it to roll it around
#13 |
C35 Crew Dually
Re: C30 question.
ok so since i did i should get a little bit more out of my drop.
#14 |
Re: C30 question.
thats what some poeple say I havent put a tape massure to it to verify for sure
| Bookmarks |
