Old 01-31-2011, 01:55 PM   #1
Garthc20
Garthc20's Avatar
Question whats the best valve cover gasket ?
I just changed my oil and I find my 4 dollar a quart oil is leaking out the valve cover on the drivers side WTF Im thinking I need a new gasket but what is the best value on gaskets and do I need to buy two or can I get them single, BTW it on a 307 sbc
1970 Custom camper 20 lwb
1978 yamaha xs1100
(insert clever quote here)
Garthc20 is offline   Reply With Quote
Old 01-31-2011, 02:37 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: whats the best valve cover gasket ?
I would use a Felpro metal impregnated gasket, if it were me.
Frank
piecesparts is offline   Reply With Quote
Old 01-31-2011, 03:47 PM   #3
cam.man67
cam.man67's Avatar
That's what I use.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 01-31-2011, 03:49 PM   #4
mr48chev
mr48chev's Avatar
Yep the steel reinforced Fel Pro is what I have had the best luck with.
mr48chev is online now   Reply With Quote
Old 01-31-2011, 03:58 PM   #5
'70_402
'70_402's Avatar
talk about the can of worms you just opened... haha... if installed correctly the cork ones will work great...
but if you are planning on adjusting valves often or taking the covers off more than once or twice a year i'd go with the rubber ones like stated before..
'70_402 is offline   Reply With Quote
Old 01-31-2011, 04:25 PM   #6
68Stepbed
68Stepbed's Avatar
Every set of rubber gaskets I ever used leaked. Cork have always worked best for me, but as stated above, they must be torqued correctly.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-31-2011, 04:55 PM   #7
tawd77
Felpro rubbers always worked GRRRRReat for me! Hmmm, just had a craving for cereal...
tawd77 is offline   Reply With Quote
Old 01-31-2011, 05:09 PM   #8
DT1
DT1's Avatar
I just had a problem with my valves covers sealing. The covers are stock steel and as flat as a pancake but I still couldn't get them to seal. I finally got these felpros from Summit racing and no more leak!
http://www.summitracing.com/parts/FEL-1604/
DT1 is offline   Reply With Quote
Old 01-31-2011, 06:45 PM   #9
sjarrett71
sjarrett71's Avatar
I use the cheaper Felpro set and have had great luck with them. I retighten them ever so often as they settle but I haven't had a leak yet and it's been several months since the install.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 01-31-2011, 06:59 PM   #10
68 Stepside
huh?
68 Stepside's Avatar
I've used Skip White's metal core rubber gaskets with success in the past. They even come with new (longer) studs too.
You can find them on eBay.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 02-04-2011, 04:04 AM   #11
Clutch442
Clutch442's Avatar
I use the Edelbrock rubber ones that are fiber in the middle. I had to use the thick ones to get my valve covers to fit and not hit the intake. They work really well, but not everbody needs 5/16" thick gaskets.
Clutch442 is offline   Reply With Quote
Old 02-04-2011, 04:49 AM   #12
72shortbed12
I've tried both rubber and cork and had leaks but I'm also running cheapo covers. Finally bought the spreaders and that did the trick.
1972 K10 4wd Swb 350, 4 speed, 205 t-case Sold
1971 Cheyenne 2wd Lwb 350 4 speed Sold
1972 K5 blazer 4WD auto A/C
72shortbed12 is offline   Reply With Quote
Old 02-04-2011, 11:44 AM   #13
leddzepp
Moderator
leddzepp's Avatar
Use rubber gaskets. Cork is porous and WILL eventually leak.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-05-2011, 10:21 AM   #14
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I'm using the thick Cork ones and will replace them with the rubber ones. I need the thick ones to allow the stock valve covers to clear my Scorpion roller rockers.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-05-2011, 11:21 AM   #15
big_al_71
big_al_71's Avatar
Change both and I used Felpro also get some ARP valve cover bolts and you are done...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 02-05-2011, 12:51 PM   #16
Zoomin
Man of Mini-Talents
Zoomin's Avatar
A set of spreaders can help, but not much can overcome a cheap set of chrome covers.
Zoomin is offline   Reply With Quote
