Old 01-31-2011, 03:52 PM   #1
jamie72k5
61 c10 Frontend
Im trying to find out some info on 60-66 c10's I just bout a 61 and I keep hearing that they did not have a coil spring front end until 63 but mine does.
Can someone tell me for sure.
jamie72k5 is offline   Reply With Quote
Old 01-31-2011, 04:04 PM   #2
k1rodeoboater
Re: 61 c10 Frontend
Are you sure you have a 61? Did you cross check the vin to make sure?
k1rodeoboater is offline   Reply With Quote
Old 01-31-2011, 04:13 PM   #3
jamie72k5
Re: 61 c10 Frontend
I checked the vin tag to the title and someone may have changed it long ago im not sure I have had alot of 67-72 and 73-87 trucks this is my first of this body style. did a 61 have coil springs in the front?
Old 01-31-2011, 05:05 PM   #4
jchav62
1962 C-10
jchav62's Avatar
Re: 61 c10 Frontend
61's did not come original with coil springs. 60-62's came with torsion bar front ends. Your truck may have been converted.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 01-31-2011, 05:41 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 61 c10 Frontend
have you looked up your VIN?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-31-2011, 05:44 PM   #6
jamie72k5
Re: 61 c10 Frontend
Thanks for all the info, it still has drum brakes so im guessing it would be safe to order parts for a 63-72
Old 01-31-2011, 06:03 PM   #7
jchav62
1962 C-10
jchav62's Avatar
Re: 61 c10 Frontend
Any pics of the truck?
Someone may have switched the numbers and title.
Joseph Chavez
Old 01-31-2011, 07:16 PM   #8
jamie72k5
Re: 61 c10 Frontend
I know that in not the correct grille for a 61
Old 01-31-2011, 07:17 PM   #9
jamie72k5
Re: 61 c10 Frontend
It makes since that the vin tag was changed best i can tell its could be a 63 titled as a 61
Old 01-31-2011, 07:22 PM   #10
jchav62
1962 C-10
jchav62's Avatar
Re: 61 c10 Frontend
That's exactly what happened. It's a '63.
Joseph Chavez
Old 02-01-2011, 01:34 AM   #11
Captainfab
60-66 Nut
Re: 61 c10 Frontend
I agree.
The grill is a '63
The fender emblems are '63
The hood is the '62-'66
And the front suspension is coil spring
Does it have mechanical clutch operation or is it hydraulic?
Old 02-01-2011, 09:30 AM   #12
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Re: 61 c10 Frontend
another difference would be the frame itself. the 60-62 frame should look like this:
with a big X in the middle. the later frames don't have this X
frame width is also different, at the rear, the frame rails on the 63-66 are 34 inches, outside to outside, the 60-62's are 42 inches.
Larry
fleetsidelarry is offline   Reply With Quote
Old 02-02-2011, 12:13 AM   #13
jamie72k5
Re: 61 c10 Frontend
I have not been under it other then strapping it down. Im sure its a its a 63. makes finding parts cheaper and easier for me. Thanks guys for all the info. Im sure I will have more questions as i go.
