Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-31-2011, 05:20 PM   #1
vjjack04
vjjack04's Avatar
Stainless steel brake line flaring
Folks,
Need to flare and bend some new brake line. I need a relatively cheap but good flaring tool and a bender for my new 3/16 stainless steel...any one with experience and or a specific product suggestion?
Last edited by vjjack04; 01-31-2011 at 05:23 PM. Reason: Posted accidentally before finishing
vjjack04 is offline   Reply With Quote
Old 01-31-2011, 06:15 PM   #2
cdowns
cdowns's Avatar
Re: Stainless steel brake line flaring
to flair stainless properly it's best with a hydralic flair tool they're in the $500 range
Old 01-31-2011, 07:42 PM   #3
cparman
sharp as a marble
Stainless lines are tough to bend and flare. I have done some 3/16 lines, but I have a Matco tubing bender kit. The tough part is to make the double flare. The darn stuff is so hard the flares come out poorly, unless you take your time.
cparman is offline   Reply With Quote
Old 01-31-2011, 10:08 PM   #4
cableguy0
You CANNOT flare stainless with a hand flaring tool. You will crack the tubing. The only tool capable of doing it is a hydraulic flaring set. I paid 480 for mine but it makes nice pretty double flares in stainless.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 01-31-2011, 10:17 PM   #5
ERASER5
ERASER5's Avatar
Save yourself some trouble and get the NiCop tubing. You will NOT be happy bending stainless without really good (read $$$) tools.
The NiCop will not rust and will bend to your will quite easily.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 02-01-2011, 10:27 AM   #6
Shane
Shane's Avatar
... or buy pre-bent. I can't stress this enough.
Shane is offline   Reply With Quote
Old 02-01-2011, 02:07 PM   #7
vin63
It's Better With Nitro
vin63's Avatar
Originally Posted by vjjack04 View Post
Folks,
Are you switching out to AN fittings? I ask because stainless tubing does not take well to double flaring. I only do 37-degree single flares on stainless tubing. As far as a hand flaring tool, I use a Roto-Flare that is more commonly found in the aircraft supply industry. I've used my old steel SnapOn tube bender for many years...stay away from the plastic or composite hand benders because the stainless tubing can be rigid.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-02-2011, 12:33 PM   #8
vjjack04
vjjack04's Avatar
Old 02-02-2011, 12:36 PM   #9
vjjack04
vjjack04's Avatar
Yes, I will be using AN fittings and flaring 37 degrees. Should have mentioned this in the first place.
Old 02-02-2011, 06:38 PM   #10
pig rig
pig rig's Avatar
all my benders are swagelok witch is made for stainless tube their probly the best benders you'll find and they aint cheep
http://www.swagelok.com/search/find_...9-501f774bb60d
and swagelok is a great for stainless tubing fittings super high pressure stuff
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 02-04-2011, 08:33 PM   #11
vjjack04
vjjack04's Avatar
Thanks again. I will be using the 37 degree AN type connections. I think I have a good flare tool looking for a bender..
Old 02-05-2011, 10:35 AM   #12
Shane
Shane's Avatar
imperial or parker for the tubing bender
Old 02-05-2011, 11:25 AM   #13
lazypineapple
lazypineapple's Avatar
www.ormebrothers.com
sells anealed tubing.
this worked well for me, doing a 37degree flare with a hand held flaring tools.
trick is to heat the end before flaring.
google is your friend
lazypineapple is offline   Reply With Quote
Old 02-06-2011, 04:38 PM   #14
vjjack04
vjjack04's Avatar
i got the Ridgid flare tool....we'll see. I think trying to get the 37 degree flare for the AN fittings shouldn't be so hard. I will let y'all know.
