01-31-2011, 06:35 PM | #1 |
Lq4 wire harness
I am in the middle of reworking my harness to put in my 67 c10. I have a 6.0/4l8e setup out of a 99 chev 2wd. I am following instructions from http://www.lt1swap.com/2000harness.htm but am wondering about a couple of wires not mentioned. They are wires coming from connector c2 that go to the neutral safety switch. There is a pink, 2 light greens, and a yellow, as well as a black. Is this plug supposed to be cut off? The alphanumeric group from connector c2 are: e3, a9, and f11
01-31-2011, 06:44 PM | #2 |
member #16
Re: Lq4 wire harness
Heres a link to the LS swap forum under engine drivetrains. You will be more likely to get an answer there.
http://67-72chevytrucks.com/vboard/f...play.php?f=206
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
01-31-2011, 06:45 PM | #3 |
69' Chevy Stepside
I don't think you need that part of the harness, its probably for the original truck it came out of to tell the dash indicator what gear the transmission was in. In my swap, I'm not running the neutral position switch harness. The PCM defualts to the "DRIVE 4TH" position without the harness connected. I know many other people don't have it wired up either. Hope that helps.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
01-31-2011, 06:49 PM | #4 |
Thanks for the quick info guys. I found some other material that agreed with you. (http://67-72chevytrucks.com/vboard/a.../t-380717.html) Thank you very much!
Tags |
thank you!!!! |
