01-31-2011, 08:25 PM | #1 |
sway bars with air ride??
hey guys so ive been driving my 68 quite a bit now with my bags done and the truck has alot of body roll, is it worth it to put sway bars on it front and rear?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
01-31-2011, 08:49 PM | #2 |
Grandpa in the rustmobile...
Re: sway bars with air ride??
I dunno about bagged, but springs, swaybar was probably one of the top 3 best things ive done to my truck!!!!
Front bar that is, no experience with rear. Wanna DIY link on how to do this and save $? I can get it if ya want (if you aint seen it already)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
01-31-2011, 08:55 PM | #3 |
its all about the +6 inches
I've never driven a 67 - 72 pickup that needed one in the rear, but, one up front is pretty much manditory IMO. I had a short/fleet that I swear the door handles would almost hit the road in a hard turn.
Now on my burb... that sucker could use a rear sway bar. It had no sway bar when I first got it as a 3/4 ton. Lowered it and converted it to a 1/2 ton with a bar, but it still leans a lot in the turns. But suburbans have a lot more weight up high compaired to a pick up. |
01-31-2011, 09:11 PM | #4 |
If you decide to put one on. look for one from a One ton, there bigger. actual dimension differences I'm not sure of at this moment,but it is a direct bolt on. I pulled one from an 84 c30 my dad crushed couple weeks ago. Andy that might be what you should try on your burb.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
01-31-2011, 09:47 PM | #5 |
I've got bags with a front sway bar and have been driving mine on the freeway for the last 3 weeks 65-70 mph no body roll on freeway transitions what so ever. Drives as good if not better that my 07 pickup. I've got a little bigger than stock sway bar.
